Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-26-2002, 01:18 PM
Hobbyguy Hobbyguy is offline
Garage is empty, add now
Hobbyguy is starting off with a positive reputation.
Truck Pulls Left Under Hard Braking
My truck has recently developed a problem that I am hoping someone can help shed some light on. At about 12,000 miles, it suddenly started pulling hard left during braking. I took it to my dealer and they replaced rotors and calipers. Seemed ok at first, then two weeks later, it was back. It seems to be more of a drift than a pull, but I can easily change lanes based upon braking pressure. Once again to the dealer where they spent three days. They eventually called and said we have done the best we can but it will still pull "slightly" under heavy braking. They also said it was not brakes and that they were able to make it better by playng with the track bar and alignment. It was better but it is still a problem. I am debating what actions I need to take. Can anybody give me any insight? A search found some issues with Excursions but not with the SD.
  #2 (permalink)
Old 04-26-2002, 01:45 PM
odie780 odie780 is offline
odie780 is starting off with a positive reputation.
A cheap thing to try is rotating your tires. There is this little thing called radil pull that can happen if you have ran your tires under inflated or have changed the rotation of the tire.
__________________
99 F-350 DRW 7.3, 6spd, 4:10
  #3 (permalink)
Old 04-26-2002, 01:57 PM
You are absolutely correct that this can cause it. However, in this case, I have been through just about every combination of tire positions possible. That was the first thing the dealer tried both times I have taken it back in. If it helps at all, the problem first appeared while I was about 1000 miles into a long trip. It was fine one day and then started the pulling the next, with nothing I could identify happening in between.
  #4 (permalink)
Old 04-26-2002, 07:29 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
This could be way off but ,what if the abs unit is malfunctioning and
not applying equal preasure to the system. have you taken it on a dirt road or gravel road and tried to lock them up?
This drift is it ocurring without brakes applied also? not sure from your
description.
some more things to chk
Ball joints
wheel bearings
spring hangers and bolts,
tires inflation
alignment
my other sugestion is have another dealer look at it
don't let them give up on it
did you hit a curb or pothole?.
were you towing anything while on your trip?
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #5 (permalink)
Old 04-26-2002, 08:49 PM
Rich,
Good questions. Actually, between the time it was fine and the problem started, my wife and mother took it on a 200 mile trip to an airport to pick up my son. She swears that absolutely nothing happened and I have never had any reason to doubt her so... That said, I can't be sure.
I have been in the dirt but have not had any reason to brake hard enough that I could tell if one side was trying to lock. There is a loud clunk in the left front when I turn the wheels all the way the the right but the dealer swears it has nothing to do with the problem. I have to go in again for this so I will push to have them look in the other areas you mention. I appreciate your help.
Randy
  #6 (permalink)
Old 04-26-2002, 08:51 PM
Rich,
I missed one of your suggestions. The alignnment has been checked and done several times during this adventure, so I suspect it is as good as it gets. Also, the truck tracks just fine when the brakes are not being applied.
Randy
  #7 (permalink)
Old 04-26-2002, 09:24 PM
FortyFords's Avatar
Now you mention a clunk when turning ,possible locking hub not releasing
or ujoint binding.
I'm assuming when the dealer replaced all those things you said ,he replaced the pads.
What was their reason for replacing the rotors and calipers?
We've had some caliper bolts becoming loose and striping causing clunking when stoping.
What is also key ,Why were they adjusting the track bar! for a pull when brakeing?
I ramble somtimes just to put thoughts out there to help for problems.
let us know the fix if they find it
Sometimes as fresh set of eyes on it might help!
Also one dealers alignment rack may not be equal to anothers
Still have them chk the abs to be sure its working fine
Rich
not with rocks
__________________
  #8 (permalink)
Old 04-26-2002, 09:47 PM
I had a 99 3/4 ton Dodge (company truck)that did the same thing. There was a TSB about the pull problem I was having and it had something to do with the pad size. I know it sounds off the wall but if anyone has access to TSB for that year 4X4 with a V10 it may give you something to work off of. When I hit the brakes on that truck you realy had to hold on. Just a thought.
__________________
  #9 (permalink)
Old 04-26-2002, 10:09 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
wolfmanagh is starting off with a positive reputation.
HEY odie780
Do you know any more on the TSB on the 99 dodge??? Like a referance number, website.
I have a friend with one and he has similar problems. The dealer won't admit anything is wrong.
__________________
2001 F250 4X4 SD Offroad Diesel
http://www.ford-trucks.com/user_gall...id=186898&.jpg
And now 3/08 a new to me 98 E350 PSD
  #10 (permalink)
Old 04-26-2002, 11:07 PM
autotech autotech is offline
autotech is starting off with a positive reputation.
Post Truck Pulls Left Under Hard Braking
Several people have had this problem, and Ford has not been able to come up with a good (cheap) fix yet. I've heard that is caused by a suspension problem, not brakes, tires or wheels. Apparently, when you brake hard, the front axle winds up slightly; when this occurs the wheels toe left and the truck goes left. Since it toes left, you shouldn't feel much in the steering wheel, right? If it were a brake, tire or wheel pull, you would feel the reaction in the steering wheel.
The soft spring bushings allow the front axle to wind up. They may have some stiffer bushings out by now, which may help.
There is also a brake pull that was caused by mis-matched front brake pads; I think there was a bulletin out on that. This could cause the brake pull either left or right, and you may feel it in the steering wheel. If your brake pads cause a left pull, and you have the axle wind up, then it will really pull left.
By the way, the NHTSA has a safety investigation on this subject; EA01-004. If your pull is real bad and Ford can't fix it, you might want to report it to them at: www.nhtsa.dot.gov
If its a real safety problem, they may be able to require Ford to recall and fix them.
  #11 (permalink)
Old 04-28-2002, 04:53 AM
FortyFords's Avatar
I wanted to bring this to the top again
Good info in the last post by Autotech
Thanks
Rich
not with rocks
__________________
  #12 (permalink)
Old 04-28-2002, 10:04 AM
Yeti's Avatar
Yeti Yeti is offline
Yeti is starting off with a positive reputation.
I had a loud "clunk" when I would turn to the left, full lock and again when I would start to bring the wheel back to the right.
After checking everything, I had my daughter turn the wheel back and forth, finally I saw the problem.
The track bar bracket was loose, the front bolt holding it to the frame loosened up and was allowing the bracket to move from the frame and then pop back when you would turn the wheel back.
I got rid of the stock 19mm and put in some 3/4 with 1/4 washers and no problem anymore.
Also with play in the bracket of the track bar, I had driffting also.
Just a thought...
__________________
I'm an ENIGMA
  #13 (permalink)
Old 04-28-2002, 10:17 AM
[updated:LAST EDITED ON 28-Apr-02 AT 11:19 AM (EST)]>HEY odie780
No I sure don't. I have a friend that works for a dodge shop up in PA I will try to get with him today to get the info.
Or if you want you can try posting it on www.allpar.com they have a few guys on this site that know what they are talking about (very few that is).
__________________
  #14 (permalink)
Old 04-28-2002, 08:44 PM
I have a good feeling you are correct. When they were investigating the issue, the first thing they did was replace pads, but that did not resolve the issue. The guy that seemed to have the most insight, not the service manager, suggested that he did not believe that brakes were the problem. He focused upon the suspension in everything he did, so I suspect he had information from Ford that that was where he needed to look.
You are correct about what I feel in the steering wheel. It is really a very gentle pull to the wheel, but the truck drifts anyway. Hopefully, the service guys are up to the task. This is generally a good outfit and they do seem to work hard to correct things. All but the service manager anyway.
Randy
>wheel.
>help.
>www.nhtsa.dot.gov
  #15 (permalink)
Old 04-30-2002, 03:51 PM
mjnova mjnova is offline
mjnova is starting off with a positive reputation.
There are a ton of reasons a truck can pull under braking here are a bunch of questions to walk through.
1.Is the pull in the steering wheel or does it just pull when applied.
It can be in the rear brakes even if the wheel pulls.
2. Line pressure-side to side and front to back.
3. Pads that are glazed.
4. Bent front end parts---Sway bar loading the front side
5. Tires rotate everywhich way
6 Rotors that crack or have cracks
Tags
1999, abs, braking, breaking, clunks, f250, ford, hard, left, light, pulling, pulls, steering, truck, turns, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
