Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-01-2004, 08:28 PM
ron78supercab is starting off with a positive reputation.
body lift?
I wanted to no if anybody had problems installing a body lift on 2wd 78 f150 power steering, supercab. I was goin to order one till I seen the footnotes , it stated that it would not fit on ones with the steering box behind the front axle close to the firewall,any body see a problem, its only going to be a 2in lift.
__________________
1978 ford supercab WiW4wd
  #2 (permalink)
Old 02-02-2004, 07:06 PM
78Extended is starting off with a positive reputation.
body lift
ron the problem with lifting a 2wd with the box that close to the firewall the steering shaft from the column to the box will be to inverted and bind up.
  #3 (permalink)
Old 02-02-2004, 07:29 PM
Alright, What do you think about getting coil springs about 2or 3in bigger ,any problem with that?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
