5.4 Triton engine tick - Ford Truck Enthusiasts Forums
Old 02-01-2004, 12:08 PM
km7648 km7648 is offline
km7648 is starting off with a positive reputation.
After running low on oil very briefly, my 2001 F-150 has an unusual engine noise.
If you drive at about 65 mph and back off on the throttle, there's a ticking sound that sounds like engine ping.
The strang this is that the sound comes only when backing off on the throttle at about 65.
There's no noise at idle, cold, accelerating etc. Drive over or under the 65 (3,000 rpms) and it's silent.
I'm thinking a lifter, push rod or a rocker got damaged?
Old 02-01-2004, 12:13 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Hi and welcome to the forum.
The 5.4 doesn't have pushrods or lifters. It has overhead camshafts with cam followers and lash adjusters.
It is weird that it only does it when decelerating. I wonder if there is a small exhaust leak somewhere causing the noise.
Jimmy
Old 02-01-2004, 12:29 PM
Already you've helped.
I was told that the 5.4 valve lash is non-adjustable and that replacement was the only option.
Would you have a link or information to the lash adjusment procedures?
Old 02-01-2004, 12:33 PM
LxMan1's Avatar
They are not adjustable. They are hydralic like a lifter. They take up the lash between the cam follower (like a rocker arm) and the valve.
I have never had one of these engines apart yet, but I am sure that they are similiar to the TurboCoupe T-Bird that I did.
Jimmy
Ticking Noise lmarkie 1997 - 2003 F150 24 02-25-2016 02:16 PM
E99 smoking, low power, strange noises SaintITC 1999 - 2003 7.3L Power Stroke Diesel 25 02-09-2015 09:17 AM
Lifter Noise??? olds68cutty 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-24-2013 10:29 PM
Tick, Tick, Tick gcozmo 2004 - 2008 F150 35 01-09-2010 01:36 AM
Lifter has a flat...Pumping it up? SCWIDVICIOUS 1961 - 1966 F-100 & Larger F-Series Trucks 14 06-30-2006 06:44 PM
Tags
2001, 2003, 54, cam, engine, fallowers, ford, motor, noise, ping, tick, ticking, tritan, triton, tritron
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
