79 F150 Ranger Front suspension - Ford Truck Enthusiasts Forums
Old 02-01-2004, 09:46 AM
scotts77 scotts77 is offline
scotts77 is starting off with a positive reputation.
This might be a dumb question I know, but the front suspension looks pretty complex on my 79 F150 Ranger lariet. Its different than my 77 custom. Is it some kind of special package or something that came on the Rangers or what?? I cant really describe it because I didnt take a good look at it, all i know is its totally different than my 77..
Old 02-01-2004, 11:01 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It should be the same. The Ranger is just a trim package
Old 02-01-2004, 11:12 AM
Hmmm I will have to look at it again, I could have swore it looks different. The 79 looks like it could handle alot more weight.
Old 02-01-2004, 07:11 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Check the GVWR numbers.
Old 02-01-2004, 08:33 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Is one of them a Camper Special? They had dual shocks and bigger diameter coil springs. I think 4x4's also had dual shocks up front.
Old 02-02-2004, 06:41 PM
ncl ncl is offline
ncl is starting off with a positive reputation.
Not all 4x4's had dual shocks I think it might depend on the gvwr rating on the truck Im not sure, I know the trailer specials came with dual shocks up front My 77 has dual shocks but I dont think its factory cause it didnt say it as an option on my build sheet but the gvwr on mine is 6500 lbs dont know if that is normal or on the heavier side for the F150.?
Old 02-02-2004, 10:56 PM
Matts72's Avatar
Thats the heavy side, most are 6250.
Old 02-02-2004, 11:43 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
Quad shocks were an option, and I'm guessing that option increased the GVWR a little. Mine with quad shocks is 6500. My dad has an almost identical truck without the quad front shocks and his is 6300.
79 f150 4x4 351w shortbed w/ dual front shocks RedUgly77 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-19-2008 05:01 PM
F150 or F250?? Bill'sBoy 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-06-2004 06:50 PM
Difference between a F150 and F250/350??? coolmint94 Clutch, Transmission, Differential, Axle & Transfer Case 1 07-04-2004 02:51 AM
Diferences between f100, f150, ranger, lariat, etc.... ladiabla74 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-20-2004 08:51 AM
radiator support interchange Redj 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-07-2004 09:40 AM
Tags
1977, f150, front, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
