Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-31-2004, 10:04 PM
gtm245 gtm245 is offline
gtm245 is starting off with a positive reputation.
SuperTech oil filters
The SuperTech oil filter box says:
98% single pass efficiency
99% multiple pass efficiency
Purolator PureOne website says:
99.7% single pass efficiency
98% multiple pass efficiency
Now my question is that Purolator says its PureOne is ranked #1 in both SAE filtration tests, but clearly the SuperTech is ranked higher in the multiple pass test. Whats the deal? Both filters use the SAE J806 test, so how can the PureOne claim to be #1 in both tests when the SuperTech has a higher eficiency %.
Also, how can the SuperTech have such outstanding efficiency numbers and still only cost $1.98. The numbers are either false or the SuperTech is an awesome deal. (By the way I was also wandering if the SuperTech has metal endcaps or cardboard like the dreaded FRAM)
Thanks everyone!
  #2 (permalink)
Old 01-31-2004, 10:10 PM
JustinH's Avatar
JustinH JustinH is offline
JustinH is starting off with a positive reputation.
supertech is made by champion labs. It is a well made filter, I use it in all my beater winter cars. My car and my truck however get motorcraft filters. They have a unique rubber anti-drainback valve that prevents dry clatter when you start it up.
If its a ford then put a motorcraft filter on it.
  #3 (permalink)
Old 01-31-2004, 10:27 PM
The anti-drainback valve doesn't really matter to me because my oil filter hangs vertically. I'm still wondering about the whole efficiency that I first posted. Can anyone elaberate on this?
  #4 (permalink)
Old 02-01-2004, 08:33 AM
micgang micgang is offline
micgang is starting off with a positive reputation.
I read in an article published by the American Filter Council (or something like that) that stated the efficiency ratings should not be used for marketing purposes. Notice that different manufacturers use different tests to show how great their filters work. The best thing to do is go to the manufacturers and get all of the specs for all of the SAE tests and then you can compare them yourself.
Look at this thread and you can clearly see that Supertech filters, while they have a solid design, are skimpy on filter media. I use a Wix filter for my Ford, as I love the way that they are manufactured. The motorcraft filter has an equally solid design as the Supertech, but with more media, so it seems like a good option as well.
http://theoildrop.server101.com/ubb/...c;f=6;t=001207
  #5 (permalink)
Old 02-01-2004, 08:42 AM
oppy's Avatar
oppy oppy is offline
oppy is starting off with a positive reputation.
I'm sure I'll get flamed for this, but I think any brand of filter will do a fine job in your engine. They all are tested against and exceed OEM requirements.
The key is not what filter but when you change your oil. If you change it when you're supposed to you'll do fine.
__________________
02 F250 4X4 SC 7.3 PSD
93 F150 4X4 SC 5.0
93 Ranger STX 4X4 4.0
90 BII wheelin' rig
68 F250 4X2 360
68 F100 4X2 360
92 Ford NH L553 Loader
I bleed Ford Blue
  #6 (permalink)
Old 02-01-2004, 08:51 AM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
I use a Supertech over a Fram, If you just compare the quality hand and hand you can see the difference. My wifes Dodge Intrepid takes a PH16 or St16. There is a huge difference. The supertech looks to have a lot more flow.
__________________
1990 F-250 4X2 300-I6 C6
1993 F-250 4X4 460 ZF-5speed
  #7 (permalink)
Old 02-03-2004, 11:13 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation. horsepuller has a spectacular reputation.
Quote:
The anti-drainback discussion was split from this thread and made into a separate topic Thread Spinoff: SuperTech oil filters (Anti-drainback valves) Let's try and steer this topic back to filter effeciency.
__________________
Scott
On vacation. See ya!
  #8 (permalink)
Old 02-05-2004, 02:34 AM
peppy's Avatar
peppy peppy is offline
peppy is starting off with a positive reputation.
http://www.frankhunt.com/FRANK/corve...y.html#warning
http://www.theautochannel.com/e_about/filters.html
__________________
91 F-150 XLT SuperCab 4X4 5.0 AOD 1356 L/S Front & Back
  #9 (permalink)
Old 02-07-2004, 04:01 PM
I posted above that the Supertech filter media was skimpy for the application, I think it was a Honda. Anyway, out of curiosity I went and cut open a ST2, the Supertech for my application (equivalent to FL -820S) and here are the results. The filter has more media than I expected. It was fairly well built. The bypass looks a little suspect, but I admit that it would be hard to say how well it works.
Filter Media:
http://home.comcast.net/~micgang/wsb...D-1324326.html
Other parts:
http://home.comcast.net/~micgang/wsb...D-1324327.html
I will take apart some other filters that are equivalent to the FL-820S so those of us that use them can judge for ourselves.
I will stick with the Wix.
__________________
2002 Explorer EB 4.0L 4x4
  #10 (permalink)
Old 02-07-2004, 10:25 PM
Does everyone agree that for $1.98 it's a darn good oil filter? I think I might use this oil filter because it's made by champion labs, it's only $1.98, and the 98% SPE and 99% MPE are pretty impressive to say the least. What about their oil? It's SL and GF-3 rated and I'm under the impression lately that as long as the oil is SL and GF-3 rated then it is of high quality and should do as good as any other same rated oil. I'm thinking that I couldn't get anymore life out of my engine by using Havoline, Castrol GTX, Valvoline, or even synthetics rather than SuperTech.
  #11 (permalink)
Old 02-07-2004, 11:03 PM
I know the SuperTech 5W30 has a good dose of moly in it and has shown good UOA. I use it in my truck in the winter. When I changed the oil last week I noticed it was really black and my oil pressure was about 20 psi lower, but I hadnt changed it since september. I wouldnt go longer than 2500 miles on the oil because mine looked shot! but I can do a complete oil change for $7.50. I am puting a new motor in in the spring.
__________________
  #12 (permalink)
Old 02-08-2004, 11:30 AM
68torino's Avatar
68torino 68torino is offline
68torino is starting off with a positive reputation.
As far as oils turning black any vehicle I have owned from low mileage motorcycles to high miler trucks and vans my oil always goes to a very dark brown to black. Any oil research I have looked at states that if your oil gets dark that is because it is capturing and retaining the contaminats\dirt\sludge so it's doing it's job. Now as I have never owned a new motor except for lawnmowers then I have had to work with what I bought from someone else. I have used all different types of oils including synthetics. I just use dino and 3000-5000 mile change outs.
__________________
Duane
68torino
1989 F250HD XLT LARIAT 351 ZF5 sp 4X4
1991 Aerostar E4WD XLT
1992 Crown Vic ex. fed car
  #13 (permalink)
Old 02-12-2004, 04:19 PM
Lone_Ranger01 Lone_Ranger01 is offline
Lone_Ranger01 is starting off with a positive reputation.
Supertech is made by QuakerState. I know because I work at Wal-Mart in the automotive department, and it comes from QuakerState
__________________
http://www.ford-trucks.com/user_gall...&photoid=35316
2001 2.3 I4 Ranger,5-spd, XLT Stepside, Reg Cab
Loud pipes save lives!
  #14 (permalink)
Old 02-14-2004, 10:20 AM
Rand Rand is offline
Rand is starting off with a positive reputation.
Not anymore. Wal-mart ditched them. Look again at your bottles.
I believe the CURRENT st oil is ""made"" by warren distro.
Rand
  #15 (permalink)
Old 02-14-2004, 10:27 AM
BlueRanger94 BlueRanger94 is offline
BlueRanger94 is starting off with a positive reputation.
I bought a 5qt of the 10W30 for my dads old pickup yesterday and it makes no statement of who makes it other than its made in USA. The guy who works for Walmart might have some insight if he is reading the shipping labels on the pallets.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
