Carb replacement for 460
75pup
For a low cost solution grab an Edelbrock 1406 600 CFM off e-bay.
Also a Holley 4160, 600 CFM is a pretty much direct replacement for the Motorcraft/Holley,4180 600CFM that is the factory unit. They have the Ford auto trans kick down. There is an adapter available for the Edelbrock as well for the kick down.
replacement for 75 F350 carb
Thanks all of you for your help, I need a replacement because about every 4 miles or so the motor shuts off 2-5 minutes later it will start up, When it shuts down looking down into the carb at the bottom of the intake there is wet fuel, and it looks like the carb has already been messed with if there might be something to check for can you please advise?
Thanks again,
75pup
Thanks again,
75pup
75pup
This is what I would do first before checking into a possable carb problem.
The ignition modules on our trucks are notorious for having heat related problems. The next time the engine die's on you. Quickly get out and pull off the coil wire from on top of the dissy. Hold the wire close (about the width of a nickel) to the engine block and have someone crank the engine. You had better see some nice blue arc's jumping from the wire to the block. Hold the wire with some insulated pliers though or you may get a jolt.
If you don't see arc's jumping then you have a spark problem and not a carb problem. You probably will need a new ignition module.
Hope this helps,
Hope this helps,
hey guys sorry about being gone but i ordered an I M for the truck the company kept saying that it was on its way it took them 2 weeks to ship it out and just got it(wont use them again) lee i checked the spark as you said but i used an ingition firing indicator the pen type you carry in your pocket didn't know i had something like this well there was no spark so i changed the I M it seems to be running better and stronger it still dies but not as bad it idels longer before shutting off do you think that the carb and choke may need adjusting?
thanks 75pup
thanks 75pup
Paso1
03-09-2015 12:22 PM
Two Lane Black Top
08-04-2013 10:45 PM
rockcrawler_101
11-15-2011 11:19 PM
powerstroker100
11-23-2010 04:54 AM
az4x4bronc
02-14-2010 08:07 PM
