Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Where is Ford in the drag HP battle
Old 01-30-2004, 05:42 PM
FRECSF's Avatar
FRECSF
FRECSF is offline
Where does ford lie in the big HP world like Top Fuel or Funny Car. Looks like to me they are right there in the funny car wins with John Force.
What size engine does he run and how much HP compared to the other makers? I have tried to research the engines in his mustangs but I can't find any references to it.
In my opinion, this demostrates the real potential of an automaker to produce street HP. If they do it at that level, then street HP should not be a problem, right?
Old 01-30-2004, 07:03 PM
Ev2Demon's Avatar
Ev2Demon
Ev2Demon is offline
All Fuel (Nitro) motors in the NHRA are currently based on the Chrysler 426 Hemi design, Forces included. They are bored and stroked to displace 500 cubic inches. They burn up to 90% nitro and make 7000-8000 horsepower.
The only thing Ford about Forces cars are the little stickers on the carbon fiber body.
Old 01-30-2004, 10:15 PM
V10KLZZ71S's Avatar
V10KLZZ71S
V10KLZZ71S is offline
JOHN FORCE and FORD are developing a new FORD top fuel engine
Old 01-30-2004, 10:38 PM
Ev2Demon's Avatar
Ev2Demon
Ev2Demon is offline
I heard that too. It sounds like it won't be on the track this season though.
I'm curious to see what combustion chamber they use. Shotgun?
Old 01-31-2004, 12:15 AM
MEPR's Avatar
MEPR
MEPR is offline
i realy dont see where drag racing has any bearing on a company. The parts are soo far off from anything that will ever be mass produced and 90% of the stuff comes from a third party manufacturer anyway. About the only direct crosover from racing to production is the Wenkle Rotor in the RX7s and 8s
Old 01-31-2004, 10:00 AM
bigsnag's Avatar
bigsnag
bigsnag is offline
The heads on those cars are very loosely based on the old Hemi design. They are actually probably closer to resembling the old Boss heads than the Hemi heads. The basic design is there, but the valve sizes, angles, and especially the combustion chamber are totally different.
Old 01-31-2004, 02:04 PM
FRECSF's Avatar
FRECSF
FRECSF is offline
So what you are saying is the fords are all running the chrysler motors? What is up with that? If they are running chryslers then why is it in a ford. From the post it also sounds like the top fuel engines are also chrysler hemi's?
How did this come about? Why doesn't GM and Ford engines compete at this level?
Old 01-31-2004, 02:20 PM
Hillbillywagon's Avatar
Hillbillywagon
Hillbillywagon is offline
They are niether ford, dodge, or chevy by my understanding. But totaly custom all alluminum blocks designed loosly on the old hemi pattern. Their are no cooling passages in these blocks just one big chunk of machined aluminum, any cooling passages would take strength away and running the fuel them do that would be a possibly deadly combonation.
Weather say dodge ford or chevy on the side it dosent mean much. Not one single part on these cars is the same as what you get in your avearge mustang cavilier or any other production car or truck.
Old 01-31-2004, 04:16 PM
Ev2Demon's Avatar
Ev2Demon
Ev2Demon is offline
Actually, the combustion chambers are nearly identical to the 426 Hemi heads. I'm 99% sure the valve angles are identical to the 426 as well. The crank shafts will interchange as well, even though the fuel motors have longer strokes. I know a few people who have run used Fuel cranks in 426 blocks.
Here is a pic of a Brad Anderson Aluminum Top Fuel cylinder head. If you compare the chambers to that of a 426 Hemi, you will see they are nearly, if not completely, identical aside from the dual plugs. The Boss heads hade quench areas on the sides of the chambers, unlike these which are completely open just like a 426.
It is true that the blocks and heads are all aftermarket parts made from solid aluminum though.
Fomoko1
01-25-2010 07:46 AM
jimford1
36
01-06-2008 08:25 AM
erik_bishop
22
04-14-2007 06:49 PM
I6power
General Automotive Discussion
23
10-02-2005 02:16 AM
77300i6
02-16-2005 02:52 PM
Quick Reply: Where is Ford in the drag HP battle
