Diesel Gas Mileage Question Ford vs Chevy vs Dodge
It's going to vary widely, IMO. Realistically, winter all around mileage should be mid-teens or so. Towing mileage will depend greatly on load, terrain and speed. From 9-13 is the range I read about the most and what I've seen in my dmax and 6.0PSD.
Best unloaded interstate driving I've seen so far on my 6.0 is 18.5 compared to a best ever of 21.3 in my dmax.
The mileage on both motors is always way better than what I got out of my big block gassers by half again more to double.
Our Cummins HO 6-speed manual gets 16 consistently, and it's loaded 24/7 (we have a utility bed on it). When towing 10+ tons total combined weight, our mileage only drops to 13. This is significantly better than the Fords/GMs we've used, and it's a lot better than what the guys with the 6.0L Fords are getting. I've seen people on here talking about the Cummins being hard on fuel...I have NO clue where they are hearing that from.
Originally posted by AAFD
As compaired to what? I have owned 4 diesel trucks, Ive seen mileage in the low 20's to high teens. I currently get 18 with my new PSD. On my 01 dodge I saw 13 MPG towing a 11400 lb 5th wheel! Not to bad!
KC
KC
Compared to the competition it is bad "gas mileage". I think that's what he meant.
the problem w/diesel to gas comparason is that people dont realize the weight. they compare the gas mileage of their f150 to the diesel, which is alot heavier. lets compare the gas V10 in the f250 and you'll probably see a lot worse gas mileage than diesel. the diesel's may not get record breaking gas mileage empty but when you throw a few tons on there it barely changes. a big rig probably gets only a few mpg's better empty than w/a load. as for the low fuel mileage in the new diesels: i often see people in diesels going 80 mph down the highway. what do you expect. if you run it at 2600 rpm's the fuel will hurt you. if you keep it under 2k, as AAFD stated, you'll get a few mpg's better. diesel's are made for slower speeds carrying a lot of weight. if you run around empty all day every day and want to drive 80mph get s gasser.
the best way to compare diesel to gas is to look at Volks Wagens or other small vehicles. I know whith Isuzu mini trucks you REALY see how much better diesel millage. In the 80-82 KBs whith the same set up, 1.8L millage will be 23mpg, 2.2L Deisel millage will be 45mpg. Theres a good comparision, power on both motors is roughly the same as well.
