1988 460 stock power? - Ford Truck Enthusiasts Forums
Old 01-29-2004, 09:07 PM
9Volt 9Volt is offline
9Volt is starting off with a positive reputation.
Yeah probably a newbie question but I searched and couldn't find the answer... What are the output figures of a stock '88 EFI 460? Also, what are the limitations of the stock EFI system? This motor is going in a truck that will be used for a lot of grunt work and some mild mud bogging/racing. I would like around 400hp, and 500ft lbs...
Old 01-30-2004, 12:11 AM
i_alone's Avatar
i_alone i_alone is offline
i_alone is starting off with a positive reputation.
I have already posted on this, but I'll do it again
185 Hp and 270 lb/ft of torque at the rear wheels, (remember this is going through a C6, NP205 and 9")
which equates in a round about way to about 255 hp and 365 lb/ft of torque
I'm also running with the air silencers cut off of my intake, and dual 2 1/4" exhaust (a little restrictive)
Old 01-30-2004, 12:11 PM
BigBlockF-250 BigBlockF-250 is offline
BigBlockF-250 is starting off with a positive reputation.
The factory specs for the '88 EFI 460 are 280hp and 410lb-ft of torque at the flywheel.
Old 01-30-2004, 07:14 PM
i_alone's Avatar
ok, so obviously I've got alot more parasitic loss that I know of.... lol
460 efi custom chip mroth2008 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 07-21-2014 03:31 PM
EFI 460 Cam Change Chadder1313 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 03-04-2011 06:50 PM
460 Efi Camshaft Upgrade 96f350rcsrw460zf Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 52 03-03-2011 11:06 PM
Stock hp rating - 96 efi 460 bchunter Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 10-05-2007 03:24 PM
Stock EFI 460 specs bigsnag Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 03-07-2002 02:14 AM
Tags
1979, 1988, 460, big, block, efi, f250, ford, horse, hp, output, power, spec, specs, stock, tourqe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
