Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 01-29-2004, 06:25 PM
MW95F250's Avatar
MW95F250 MW95F250 is offline
Garage is empty, add now
MW95F250 is starting off with a positive reputation.
Question: F-450 vs. C-4500
My father is looking at replacing 2 of his work trucks with one. He currently has an '82 Chevy Silverado C-30 dually with a 454 and a 4 spd man. w/granny low and a '87 Chevy Kodiak C-70 with a Cat 3208 Non-turbo diesel with a 5x2 transmission. He's looking at a C-4500 dump truck which is a good compromise between the 2 current trucks. I can't get him to look at a F-450 (chevy lover since birth), but I just want to use the F-450 as a reference to the C-4500.
The truck he's looking at is an '04 C-4500 Duramax with Allison trans. and it has a 14' dump bed. It is a 1 1/2 ton chassis truck.
What is the GVWR of the C-4500, he asked me to look it up for him.
__________________
2004 F-250 XL Regular Cab Longbed 4x2 6.0L Power Stroke Diesel/Torqshift Automatic, Straight Pipes, 3.73LS, Tekonsha Prodigy
John Deere Ag, CCE, and CF Certified Technician
Kohler Certified Expert Technician
  #2 (permalink)
Old 01-30-2004, 01:30 AM
gilraine gilraine is offline
gilraine is starting off with a positive reputation.
GVWR is 16k-17,500 for the c-4500
__________________
1987 F-250 460, 4 speed and 33's
My baby is gone...
  #3 (permalink)
Old 01-30-2004, 02:05 AM
sinister73 sinister73 is offline
sinister73 is gaining momentum as a positive member of FTE.
Between the two there is a big difference.
The GM trucks are heavier duty in my opinion.
Stronger frames for one - 80,000 PSI compared to 36,000PSI.
Bigger axles with larger ratios available.
Exhaust brakes.
Generally heavier GVWR's 16K-17.5K compared to 15K.
And actually those numbers are very conservative for the 4500.
Availability of at least one Allison auto.
Tlit hood for easier access to engine compartment.
Much tighter turning radius.
Better driver visibility.
This being said, try getting Pop's to think outside the box a bit.
I would not buy the Ford or GM trucks- I'd go International.
For about the same money he can get himself a 4200 series truck with or without the low pro pkg.
And even with the low pro he's going to get at least 19,500GVWR-a 23,000LB rear axle is used in standard 4200's. He'll also have the option of either the Allison 2000 or 2400 model automatics- which blow away the 1000 series. On top of this he can get the VT365 at 230 HP/620 LBFT.(the trouble free 6.0PSD)
Last but not least- the International cab is actually layed out the same as OTR day tractors-which these have also served as BTW-whereas the Ford's and GM's have that "pickup on steroids look" to them- they look cheap.
Good luck.
  #4 (permalink)
Old 01-30-2004, 07:29 AM
MW95F250's Avatar
I think he's run across a dealer that has really marked down the 4500's and he just won't buy anything other than a Chevy. I'll mention to him about the IH, but I don't know if that will move him.
__________________
  #5 (permalink)
Old 01-30-2004, 12:59 PM
TowinBob TowinBob is offline
TowinBob is starting off with a positive reputation.
I agree with Sinister, the IHC is a far better straight frame truck. High seats, low hood excellent visibility and will turn around as sharp as a Bronco. A VT365 or a DT466 is a real truck engine made out of real cast iron. A C4500 is an oversized pickup cab, with a pickup engine and trans.
Bob
__________________
1993 F150 4X4 302 AOD
Made in the USA
  #6 (permalink)
Old 01-30-2004, 04:58 PM
93 F-250 7.3L Diesel 93 F-250 7.3L Diesel is offline
93 F-250 7.3L Diesel is starting off with a positive reputation.
Straight out of ford's website
F-450 Chassis Cab
The F-450 Super Duty Chassis Cabs have a GVWR of 15,000 lbs.
Configurations: The F-450 Super Duty Chassis Cab is available in a variety of wheelbase lengths, in 4x4 and 4x2 and, in XL, XLT and Lariat models.
Highlights: Passenger side air bag with deactivation switch now standard on all models
Trailer tow package now standard on Lariat
Manually telescoping mirrors now standard on XLT and Lariat
Rear sliding window and privacy glass now standard on Lariat
Improved seats on XLT and Lariat More powerful 7.3L diesel engine
Improved shift feel through engine and transmission calibration revision
Improved fuel economy
Major Standard Features: XLT
6.8L modular V10 gasoline engine
5-speed manual transmission
4-wheel anti-lock braking system (ABS)
Power steering
High series cloth 40-20-40 split bench seat with armrest and storage
Premium AM/FM stereo/cassette/CD player with clock and 4 speakers
Air conditioning
Power door locks and windows
Full instrumentation including tachometer
Dual dash mounted cup holders
Chrome bumper
Major Optional Features: 4-speed automatic transmission
7.3L DI turbo diesel engine with 6-speed manual transmission
Clean Fuel Fleet LEV option
Power take-off provision transmission
Rear sliding window
Snow plow package
Bi-Fuel propane (ULEV)
Option Packages: Ambulance Prep Package
Auxiliary idle control kit
Dual 130 amp alternators
Air conditioning
XL Decor Group
Chrome front bumper with lower valance
Aero halogen headlights
Straight out of chevy's website
C-4500
'NO 4X4' avaliable
2WD Regular Cab
GVWR* lbs 16,000
Wheelbase 128" with "60 CA and 100.5" CE. Includes a 6mm 80,000 psi yield strength, steel frame, RBM: 610,400 Section Modulus 7.63
Engine Vortec™ 8100 Gasoline V8 with 225 horsepower @ 3600 rpm and 350 lb–ft torque @ 1200 rpm
'6.6L Durmax diesel avaliable but has no ratings'
Transmission Allison® 1000 Series — Automatic transmission with 0.71 overdrive Torque Rating: 520 lb–ft
Fuel Tank Single 25-gallon fuel capacity — gas and diesel located midship between the frame rails, with fuel–fill neck located over top of frame rail
Frame 6mm - 80,000 psi yield strength, steel frame, RBM: 610,400 Section Modulus 7.63
My 2 cents is to go with the F-450 7.3L DI turbo diesel engine and 4-speed automatic transmission. The durajunk's aluminum heads are gonna blow off one day and the 8.1L is good but a gas hog and wont last as long as a diesel 'well maybe the it ill out last the durajunk'. The 7.3L diesel has proven its self over and over were i live and i would not drive anything else. Those chevy trucks are just trouble. Go with a relible ford.
Josh
93 F-250 7.3L Diesel 4x4
  #7 (permalink)
Old 01-31-2004, 12:20 AM
MW95F250's Avatar
I wish he would agree with me and go with a Ford or IH, but like I said, I think he's too far gone.
__________________
  #8 (permalink)
Old 01-31-2004, 04:44 PM
redmt77 redmt77 is offline
redmt77 is starting off with a positive reputation.
Ask him to look at a F-550, I thought at first that it was a F- 350 on steriods, but after buying mine and giving it a good look, the frame is heavier- looks like 5/16-3/8 thick, the rear end is a spicer unit rated at 13,500lbs-its huge! mine is a 4x4 with a 6000lb rated dana 90 front axle, springs and steering componets make light duty trucks look like toys. The F-550 is truly a medium duty truck.
__________________
Cleve
04 F-350 CC SB 4X4
6.0 Torque Shift, 08 tow mirrors, muffler delete. Xcal3 with tunes from Matt at Spartan Diesel
03 F-550 4x4
7.3 6 speed, 6637, epbv brake, high idle mod, no cat-no muff. flashpac on tow safe
77 F-150 4X4
  #9 (permalink)
Old 02-02-2004, 11:32 AM
78custom 78custom is offline
78custom is starting off with a positive reputation.
Any one seen the F650 supercruzer?
__________________
78 F-150 351M 4V
Mod's in Gallery.
Tags
450, 4500, 81, c4500, cc, chevy, compare, comparison, dually, f450, ford, forum, powerful, truck, vortec, vt365
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
