Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 05-11-2002, 09:29 PM
Magnum1029 Magnum1029 is offline
Garage is empty, add now
Magnum1029 is starting off with a positive reputation.
TONNEAU COVERS
Gentlemen,
I'm considering purchasing a tonneau cover for my Crew Cab short bed.
What have been your experiences and what are your recommendations (brands etc.) Thank you, Magnum1029...
  #2 (permalink)
Old 05-11-2002, 10:18 PM
superbent250's Avatar
superbent250 superbent250 is offline
superbent250 is starting off with a positive reputation.
TONNEAU COVERS
Hey There,
I bought an Extang tonneau cover......not sure if I would again.......I live in Ontario and therefor the studs are exposed to salt in the winter. I suppose with some routine maintenance of the studs/snaps they would be OK but I found them very hard to fasten/release in the winter. In fact I try very hard to avoid removing it in the winter for that reason. The cover contracts so much in the cold and it is damn near imposible to stretch it out in the cold to re install it if you have taken it off. I ended up damaging the cover this winter because I popped off a few studs to let some cargo stick through then when I went to re attach them once I was unloaded I could not stretch the cover enough to fit. I decided to take the cover off and roll it up and wait for a warmer day but I ran into a couple of snaps that were very stiff and then I ended up ripping one out of the cover. Not wanting to further damage the cover I decided to just leave it as it was and tie down the loose part of the cover to prevent it from flapping. Well I guess I didn't do a very good job because by the time I got home the end of the cover had cracked because it was cold and stiff and had been flapping in the wind.
Final thought,.....If it's for looks and you don't work your truck, go for it. If you are likely to be installing and removing all the time........well I'm just too lazy for that.
__________________
John
  #3 (permalink)
Old 05-12-2002, 01:21 AM
lodihoseman lodihoseman is offline
lodihoseman is starting off with a positive reputation.
TONNEAU COVERS
I bought the "Trac Top Cover" by pace edwards. It is a rolling "hard tonneau cover". It rolls up into a box at the front of the bed. It is a very nice looking cover, and very functional. It locks every 12 inches, and even comes with a light under the cover to light the bed area when the cover is closed. I would definitely recommend it.
It is a little expensive. I paid $700 to my dealer when I ordered my truck. That is only $25 over their cost. Most places want around $800 for it. So far it has been well worth it.
  #4 (permalink)
Old 05-12-2002, 08:34 AM
superdutyspv superdutyspv is offline
superdutyspv is starting off with a positive reputation.
TONNEAU COVERS
I have a Daws Better Built diamond plate tonneau that mounts to my tool box. I wanted a toolbox, to keep my stuff organized AND a tonneau. Gaylords also makes the X-2000 that will mount to a tool box as well. i thought the diamond plate would hold up better in snow country. I LOVE my tonneau! I can highly recommend it.
  #5 (permalink)
Old 05-12-2002, 08:39 AM
CEEJR CEEJR is offline
CEEJR is starting off with a positive reputation.
TONNEAU COVERS
I bought a penda nascar trucks tonneau cover and I love it. It looks good, follows the contour of the bed, and is very sturdy.
Chuck
  #6 (permalink)
Old 05-12-2002, 01:22 PM
Bluehawk Bluehawk is offline
Bluehawk is starting off with a positive reputation.
Post TONNEAU COVERS
[updated:LAST EDITED ON 12-May-02 AT 02:27 PM (EST)]I bought the Access tonneau for my shortbed. I love it. It is a soft tonneau cover that locks at the back, and has velcro on the sides. It mounts on a rail that clamps inside the bedrails, nothing attaches to the outside of your bed. You can adjust the tension so that when you lock the back down, you can't get your arm in on the sides. You can roll it and the attached support rods up from one side without it sagging in the middle and you don't have any bars to remove before putting something tall in. You can also add a set of bars ontop of the rails which will add security (I got the rally/lightbar combo through the Ford Accessories catalog.) I removed the hidden release button on mine, so that you have to drop the tailgate in order to release the cover. With the tailgate locked, there is almost no way to get inside. The cover has a ripstop material, so that it cannot be easily cut with a knife. My cover cost about $400, but, I felt it was well worth the extra money.
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4318&.jpg
F-250 SD XLT CC 4x4 Shortbed; MAAP nerf bars, Rally/Lightbar combo, PIAA 1300 driving lights, Lund bugshield, Lund SunVisor, tinted windows, K&N airfilter, Access tonneau cover, Rhino Liner, remote starter/security system, custom built console, Cobra 29 ST/WX CB with a Wilson 1000 magnet mount antenna, Realistic 500 channel police scanner, Kenwood 10 disk CD changer, Compaq laptop, SVP 100 Watt siren, and 24 Strobe lights.
Upgrades for the near future include: Warn Rio Grande pushbar with a 12,000# winch, 4" lift kit, fender flares, and 35" BF Goodrich T/A KO tires.
__________________
http://www.ford-trucks.com/user_gall...toid=4318&.jpg
F-250 SD XLT CC 4x4 Shortbed, V10,
  #7 (permalink)
Old 05-13-2002, 02:31 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.
TONNEAU COVERS
I've had 2 Extang covers. Both were snapless. I believe they are called Tuff Tonno III. I never had any problems with any of them. They do get tight in cold weather. The trick is a couple buckets of hot water and quickly snap it on. www.extang.com
__________________
Just like a sad dog at the shelter with those eyes... I had to have her: 1977 F250, 460 V8, C6 needs love: PS pump, hoses, gearbox, fan clutch, dimmer switch, blower relay, battery cables, headers, muffler, rattle kit, door seals, ignition module, Kenwood, and on and on....
  #8 (permalink)
Old 05-13-2002, 07:29 AM
harryball harryball is offline
harryball is starting off with a positive reputation.
TONNEAU COVERS
I've owned Pace Edwards... but the best I've seen is the ReTrax, mine's on order, should be here this week.
http://www.rolltopcover.com/home.html
Robert
__________________
2002 F350SD 7.3L PSD ShortBed!
  #9 (permalink)
Old 05-13-2002, 08:01 AM
dbugem dbugem is offline
dbugem is starting off with a positive reputation.
TONNEAU COVERS
I've had 2 fiberglass covers. A.R.E. and Jason. Both are excellent quality.
dbugem
__________________
2002 F-350 XLT 5.4 auto SRW supercab shortbed K&N Jason hard bed cover
2001 EXPEDITION E.B.
  #10 (permalink)
Old 05-13-2002, 11:39 AM
benr0 benr0 is offline
benr0 is starting off with a positive reputation.
TONNEAU COVERS
I installed the ROLL-N-LOCK cover. It is a roll up cover. It has worked well for me so far. Keeps everything dry. When I received the cover, the top to the canister was damaged, it had a small bend in it. I called and they sent me a new one in 3 days no questions asked.
I did much research on what I wanted, and it came down to a Pace or the Roll-N-Lock. I chose the Roll-N-Lock based on seeing both. Nothing wrong with the PE but I just liked the RNL better.
I ordered from this place because it was in the mid-west. http://www.web4jnj.com/
Hope you find what works for you.
__________________
2001 TRed F250 Lariat CC SB,4x2, Camper Pkg., V10, Auto, 3.73LS, Heated seats, Bed X-tender,Ford Flaps,Catch-all,RollNLock. 7200# Me, Wife, 2 teens, gas and gear for weekend.
  #11 (permalink)
Old 05-13-2002, 12:05 PM
TONNEAU COVERS
I looked at that one too... the final deciding factor for me was the vinyl cover. After my experience with the PE I specifically wanted aluminum, no vinyl.
The vinyl held up OK, but the dealer accidentally cut it during install and it had to be replaced. I could see accidents happening during use too easily. Also, after a year it looked dull even though I kept treatment on it, this told me it was aging. It was not the dull I was worried about, it was the possible tearing and/or cracking that comes from prolonged sun exposure and/or acid rain etc...
Robert
__________________
  #12 (permalink)
Old 05-15-2002, 09:18 PM
Gary E K's Avatar
Gary E K Gary E K is offline
Gary E K is starting off with a positive reputation.
TONNEAU COVERS
__________________
Gary E K
http://www.ford-trucks.com/user_gall...toid=4572&.jpg
The Lord is my Shepherd
  #13 (permalink)
Old 05-16-2002, 10:37 AM
Ufda Ufda is offline
Ufda is starting off with a positive reputation.
TONNEAU COVERS
Check out sportmasters.com, I have one of their hinged soft covers and it fits my 2002 SD Crew Cab short bed very nicely. The rails conform to the bed rails and seals well. It can be removed in less than 2 minutes to haul large stuff, or removed compeltely in 3 minutes. The vinyl is top notch, snaps on but is very water resistant. I purchased mine on ebay, cost me $150.00 plus shipping. The MSRP is over $300.
God and Soldiers All Men Adore
In Time of Trouble and No More
When War is Over and Wrongs Righted
God is Forgotten and The Soldier Slighted
  #14 (permalink)
Old 05-16-2002, 02:59 PM
TONNEAU COVERS
>over $300.
Ufda
Checked out the cover you purchased and I have a couple of questions.
Does the cover lift up or vibrate when traveling at highway speeds (70-80 mph) and exactly whats holding it down?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
