Overdrive button doesnt work, but its stuck in Overdrive - Ford Truck Enthusiasts Forums
Old 01-29-2004, 12:41 PM
Bullseye1 Bullseye1 is offline
Bullseye1 is starting off with a positive reputation.
What do I do replace a switch or is it a fuse, the light doesnt even light up either? The truck is out of warranty too!
Old 01-30-2004, 01:07 PM
Oklahoma Oklahoma is offline
Oklahoma is starting off with a positive reputation.
Sorry no clue here just trying to point you somewhere to maybe find out. Try checking the wiring and/or fuse schematic pages in PU manual. That's helped me on other vehicles many times isolating problems. Have you checked to see if power is coming to the unit with a multimeter? Any other things not working? Usually there are 2 or more electrical devices protected with one fuse.
Summary:
1. Anything else not working? Yes? Try to isolate possible fuse book schematics.
2. Everything else OK. Check for power to unit. Could be wiring or broken/corroded contact point.
3. If #1 and #2 OK. Always the hard part. Take apart unit and check switch if possible.
Basically, start with the easy possible solutions first. Then work down to hard ones. Someone else will hopefully know more on this particular device and chime in. These steps are just generic for problems.
Old 07-21-2010, 10:19 AM
Spool&Go's Avatar
Spool&Go Spool&Go is offline
Spool&Go has a very good reputation on FTE.Spool&Go has a very good reputation on FTE.Spool&Go has a very good reputation on FTE.
My OD Button is the same way. Stuck in overdrive as well. It used to just be iffy on functionality. Sometimes it would work and sometimes it wouldn't. Any information on this? I'm hoping its just a button or connection issue.
Old 07-21-2010, 10:34 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Most likely there's a short in the steering column. The wires run over the steering mechanism, rub over time and short out. My light doesn't work either but it does activate the OD when depressed. I already replaced the button with no change so I will have to order the whole shifter assembly.
Old 07-21-2010, 10:41 AM
Spool&Go's Avatar
I see. So you think i should go with ordering the assembly first? I suppose i'll upen up the column and have a look. Never done that before though.
Old 07-21-2010, 10:45 AM
Hit it!
I would open up the column first. You may be able to see the shorted wire and fix it with some simple splicing. I cannot find my short and it might be in the stick itself so I need the assembly. Here's a write up on how to remove the plastic shrouds on the steering column. Easy-peasy... oh and do the door chime mod too. You'll love it!
http://www.ford-trucks.com/forums/30...lly-quiet.html
Old 07-21-2010, 10:56 AM
Spool&Go's Avatar
Sweet thanks. Just three screws and it drops out huh? easy enough. But who knows what i'll find or wont find. Hope its an easy fix. I dont really like messing with electronics unless its stereo system stuff.
Old 07-21-2010, 11:06 AM
Hit it!
Three screws takes off the bottom plastic. You need to remove the ignition tumbler in order to get the top plastic panel off. That's where you'll need to snoop around for the short because that's where the wire for the transmission OD button crosses over the top of the linkage.
Old 07-21-2010, 11:10 AM
Spool&Go's Avatar
Oh, gothcha. I highlighted even more of the directions now. Good call. Thanks. I really hope its just a wire i can splice.
Old 07-21-2010, 11:15 AM
Hit it!
One last thing that I don't think was in the instructions. Disconnect the batteries.
Old 07-21-2010, 11:17 AM
Spool&Go's Avatar
haha good call. I would have probably forgot about that until i got shocked. The only thing i hate about that is having to reset all of my stereo settings. But it's not a big issue. I am going to clean my engine and need to incorporate my battery terminals anyways. I'll just write the settings down or something. thanks again.
Overdrive Light BLINKING (F250 SuperDuty) campbell99 1999 to 2016 Super Duty 73 01-11-2017 05:52 PM
Overdrive problems Jensen17J 1999 to 2016 Super Duty 1 11-03-2013 11:20 AM
2004 F-150 Won't Shift Into Overdrive kstatechris 2004 - 2008 F150 5 08-22-2012 09:30 PM
Overdrive Off Switch Not Working FAGRO 1999 to 2016 Super Duty 4 01-19-2005 08:00 PM
overdrive light flashes jeremymcelroy Explorer, Sport Trac, Mountaineer & Aviator 15 05-27-2003 08:43 AM
Tags
1999, 2000, button, diesel, doesnt, f150, f250, ford, functioning, od, overdrive, schematic, stuck, switch, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
