front bearings won't tighten up - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-29-2004, 01:19 AM
minaz minaz is offline
minaz is starting off with a positive reputation.
Angry front bearings won't tighten up
i have a 2002 f350 sd i had a bad wobble in front end, had rotors turned replace pads, now a bearing went out replaced spendal but i have the same problem the right side tighten up and i back it of a little the drivers side won't tighten up tight enough to stop the wheel the first time i just tighten it up as far as i could and now the bearing is shot and is doing the same
need to get it going for my work in 7 hr. lo0st big time today
is there any body out there that can help
Old 01-29-2004, 06:47 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
You don't want to tighten the bearing to the point where the wheel won't turn. That will cause bearing failure. You have to preload the bearing. I don't have the specs here and it varies by appliication. Usually, you tighten the bearing using a torque wrench and rotating the rotor. Sometime that's all you do and other times you back off the nut slightly. Generally if you snug the bearing while rotating the rotor and back off the nut a tad, will put you in the ball park. When you get done, the rotor should rotate smoothly yet not have any in and out movement. Grab the rotor, top and bottom, and try to rock it. There should be almost no rocking movement. If you can't tighten the nut enough, either you were given the wrong parts or something is missing.
Old 01-29-2004, 11:12 AM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Look in a shop manual or Chiltons/Haynes. Most of the heavy trucks require you to torque it really tight, I think my 94 F250 requires 200 foot pounds. Then you loosen it up and then retorque to around 50 foot pounds. Be sure to check manual for torque, it may be way different for your model.
Good Luck,
Jim Henderson
Old 01-29-2004, 03:19 PM
Is it 2 wheel drive or a 4X4? It makes a difference.
Old 01-29-2004, 04:19 PM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Its gotta be a 2wd nothing to tighten on a 4wd!!!!
Old 01-29-2004, 04:22 PM
n578md's Avatar
n578md n578md is offline
n578md is gaining momentum as a positive member of FTE.
You don't have to replace the spindle to change the bearing races on a 2wd. Plus there are 2 bearings, and inner bearing and an outer bearing.
Old 01-29-2004, 04:26 PM
He prob burn't the spindle thats why he changed it....Over tighten and heat up the bearings and lock em and spin on the spindle...Yummie
Old 01-29-2004, 04:42 PM
n578md's Avatar
That very well could be. Who knows. Statistically bearings rarely go bad on a 2wd, and bad bearings on a 2002? Kinda young for that kind of death. (unless he drives in deep water a lot)
Old 01-29-2004, 06:50 PM
n578md's Avatar
You know what else might be the problem? He might have installed new bearings without replacing the races in the hub. Since the bearings and races come as a matched set. If I remember correctly, you can't put the new bearing in an old race.
Old 01-29-2004, 07:52 PM
Quote:
That's a surprise to me. I had plenty of torquing to do on my 94 F250 4x4. Could be different for different models and years like I said.
Jim Henderson
Old 01-29-2004, 08:02 PM
n578md's Avatar
If it's a 2wd, you have to torque the Jesus nut but very little. You torque it to 21 ft/lbs while turning the rotor forward, then you stop, let the Jesus nut out 180* and then tighten to 18 ft/lbs again. That's a fairly light amount of torque. He's gonna have to take the rotors to work and use the old 30-ton press to get the old races out and press the new races in. (Remember which is the inner race/bearing set and which is the outer.)
Old 01-29-2004, 08:21 PM
A qualified mechanic might be the best answer at this point. Someone who can sort out what's wrong and correct it.
Old 01-29-2004, 08:31 PM
n578md
Thats 18 lbs/in
Old 01-29-2004, 08:32 PM
n578md's Avatar
Not the same "qualified mechanic" who turned the rotors, replaced the pads and re-installed the bearings incorrectly I hope.
Old 01-30-2004, 08:56 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
99 !!!!!
Boy we sure would like to see these type on our 4wd 's huh ???????
Oh the fun of repairable bearings !
I hate sealed bearings!
Rich
you can get those races out with a brass punch.
put your new ones in the freezer for about ten min.,put the rotors in front of the heater.
Then carry the races to the rotor in a towel,and they will just about drop right in.
We used to do this alot.
Rich
How to replace your differential pinion seal with no special tools (tech folder?) EXv10 Excursion - King of SUVs 0 12-23-2014 09:37 PM
Crankshaft change out on 302 firedawg53 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-29-2011 11:52 PM
53-56 Front sheet metal alignment procedure AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 02-12-2011 09:38 AM
Transmission Front Bearing Retainer Cover wayduq Explorer, Sport Trac, Mountaineer & Aviator 1 11-20-2008 11:47 PM
help str8racing 1987 - 1996 F150 & Larger F-Series Trucks 1 04-13-2008 05:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
