Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint & Bodywork
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
  #1 (permalink)
Old 01-28-2004, 07:46 AM
unioncreek unioncreek is offline
Garage is empty, add now
unioncreek is starting off with a positive reputation.
Question How many gallons to paint truck?
I am going to paint my 72 F100 this spring and have been pricing paint. They are pricing me for two gallons of paint for an entire paint job, is that the right amount? I thought I read somewhere in the forums that it only took a gallon to do the whole thing.
Just want to make sure that I get enough paint the first time.
Thanks,
Bob
__________________
Bob G
1962 Ford Galaxie 500XL with a Thunderbird 390/300hp
1986 Ford Ranger 2.9
  #2 (permalink)
Old 01-28-2004, 01:54 PM
Aekisu's Avatar
Aekisu Aekisu is offline
Aekisu is starting off with a positive reputation.
2 gallons would do your pickup. If you wanted to try buying less (like 1 1/2 gallons), then break the job down into sections (exterior, interior bed, interior cab, and engine compartment). That way if you run out of paint, the color matching isn't as critical.
Whatever you decide, remember to mix your separate containers of paint together before you start painting. This insures an even color mixture between the separate containers.
Just for your information, for a gallon, the 4th quart of paint is dirt cheap in comparison with the first 3 quarts.
__________________
Dennis
The Oldman's Home Away From Home
  #3 (permalink)
Old 01-28-2004, 11:31 PM
parks911's Avatar
parks911 parks911 is offline
parks911 is gaining momentum as a positive member of FTE.
Quote:
I'm doing about the same thing with my 88 F-150. I'm thinking about a Burgany color for the exterior & door jambs. & having the inside of the bed & over the rails painted black.
Should I have to buy 2 gallons of the burgany or would 1 gallon cover it?
I'm also going to clear the whole thing, should I get 2 gals. of that?
If I buy to much clear it won't be a problem. I have 2 other vehicles that need paint after my truck is done.
It isn't going to be broken down to do a peice here or there. When I paint it, it will be painted all at once & finished before the truck sees the road again.
__________________
Well that just dills my pickle!
  #4 (permalink)
Old 01-29-2004, 03:56 AM
Aekisu's Avatar
A gallon should do especially since you aren't doing the interior and interior bed.
Clear will keep almost forever. It's the activator that will go bad.
You can save your opened can of activator by displacing the air inside the can, with inert gas. I use the gas from my MIG welder.
__________________
Dennis
  #5 (permalink)
Old 05-10-2004, 12:07 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
what about just cab and front clip? my highboy has a flatbed. so wouldn't that reduce the amount of paint that i need by about 30%? also, about how much (and how hard) is it to do the interior? would that offset not having do do the box (even though the box would take much more) about how much would i need to do both?
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #6 (permalink)
Old 05-10-2004, 01:14 AM
Aekisu's Avatar
A lot depends on the paint, color, and what you are spraying over. I would probably buy 3 quarts but consider these 2 points.
1) The 4th quart is cheap, in comparison with the first 3.
2) You only need to worry about the color matching on the cab and clip. If you ran out of paint while painting the interior and had to buy extra paint, a slight mismatched shade difference wouldn't make a difference.
__________________
Dennis
Tags
car, clear, f150, ford, full, gallon, gallons, needed, paint, pickup, quarts, ranger, required, size, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
