Best Diesel Oil?
Re: Best Diesel Oil?
Originally posted by PSD6litre40
What is the best diesel oil for my 6.0L. I am using Shell Rotella-T 15w40. Is there any better oil, I have heard that the Chevron DELO 400 is good......... Help please...........
Do a search................here.......and read read read
You will learn more than you ever could have thought possible
Just changed my oil today with Motorcraft 15/40. Label says synthetic blend. Cranked it over and within a few seconds it started to idle smoother and quiter. Since its the same oil it came with from the factory, I attribute the difference to freshness.
I was wanting to change to Mobil 1 Delvac synthetic but cannot find a local dealer who carries it. Will probably order via internet and have ready for next change.
John
John
John
John
Hope it helps http://www.prod.exxonmobil.com/chann..._directory.jsp
John Try this Texas Exxon Mobil Distributor http://www.jamdistributing.com
They have an Alice location which is within driving distance.
I have been told by three different ford mechanics to use three different oils. I wish they would all get together on this! :P
One sd to use Ford motorcraft of course......sd that it breaks down around 3500 mls and would probably need to add an anti foaming agent since it is not economically possible for me to change the oil every 3500mls, because I put around 5000mls on the truck every week to every other week.
Had one tell me to use Mystic and one tell me to use Rotella.
The last mechanic I talked to sd that rotella breaks down around 2500mls.
So, I still don't know what is the best. I have an '03 F350 6.0L Which by the way is a piece of crap.
My choice is Mobile Delvac 1. The Mobile oil makes mine run smoother starts easier and is quiter.
You choice.............
Do the search......read read read
#28
Your post is hardly informative.
#30
