1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cargo light 1, dome light 0
Old 05-24-2002, 10:22 PM
weldman's Avatar
weldman
weldman is offline
There was a post last week about the inability to see the cargo because the dome light was always on.
I think it was Monsta who said that a defeat switch could be put inline, but he didn't know if the cargo light ran off the same wire, and therefore would cease to work as well.
Well, I figured out that they are not connected and put in a nice mini toggle to disable my dome light when I want to look in the bed (mounted on the dome light bezel). Very easy.
The door bottom lights stay on as they always have, but I kind of like it because it reminds me that the cargo light is on!
Hope this helps!
Matt
Old 05-24-2002, 11:57 PM
NoMo's Avatar
NoMo
NoMo is offline
Great!
How did the backup light project go?
Old 05-25-2002, 07:30 AM
weldman's Avatar
weldman
weldman is offline
[updated:LAST EDITED ON 25-May-02 AT 08:33 AM (EST)]Ah yes, the backup light install went very well.
I ended up running a 10 gauge from the junction behind the battery back to my relay behind the bumper, then wired in my ground and output to the floods. I then used a wire tap to connect the relay to my trailer reverse lights.
I have a custom cushion hitch that is used to haul heavy grain and fertilizer wagons that is supported with flat plate steel. I drilled two holes and used 6 inches of angle iron per side to allow my lights to mount either of the hitch. I am very happy!
The light that these tractor floods give out is amazing! My dad especially appreciates it as he only has the use of one eye (double vision) while driving (hopefully temporary, is improving).
I will post pics asap!
Matt
Old 05-25-2002, 09:22 AM
FXSTC's Avatar
FXSTC
FXSTC is offline
tbruz
11-15-2015 02:43 PM
JJONES7432
11-10-2015 03:22 PM
levgoo
06-12-2015 10:46 AM
Trophy_23
03-21-2014 06:56 PM
KCFordFANatic
1997 - 2003 F150
02-13-2014 07:48 AM
Quick Reply: Cargo light 1, dome light 0
