Theft Light blinking Will not start - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-27-2004, 10:07 PM
fastcatsailor fastcatsailor is offline
fastcatsailor is starting off with a positive reputation.
Angry Theft Light blinking Will not start
Went to start 97 Expedition. It turns over fine but will not start. I notice the theft light blinks rapidly. I have tried both keys. Any sugestions?
Old 01-28-2004, 12:11 AM
tsdrallyer tsdrallyer is offline
tsdrallyer is starting off with a positive reputation.
Keys have been corrupted, reciever has died, ECM has died or connection lost, brake light switch is dead or lost connection, or a thief has repgrogrammed your car with intentions of taking it. All are possiblities. I'd check the brake light switch first. Test connections and adjustment to make sure brakelighs come on when it is depressed. If they do, the next best thing is to have it towed to a dealer or the mechanic of your choice for a code reading.
Old 01-28-2004, 12:26 AM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
TSD pretty much summed it up.
I'm not patronizing you, but here's some basic information:
The Expedition keys have little microchips in them that broadcast a signal to an antenna (a plastic ring surrounding the key cylinder) when you start the truck. When the theft light blinks, it's not getting the signal.
I agree with TSD about getting it towed and having the dealer look at it. I was knee dip in this system when I was installing a remote starter, and it's not "user serviceable" as they say. It's all tied in with the computer and everything else.
The dealership should be able to reprogram the whole thing for you. It might cost a bit; just thought I'd warn you. Keys are probably going to be $50 each.
Good luck, and please keep us posted.
XXL
Old 01-28-2004, 09:00 AM
ronk1969 ronk1969 is offline
ronk1969 is starting off with a positive reputation.
hey i had the same thing happen to me just be glad it did not happen to you while going down the highway.
had to take to dealer and have the transponder replaced at a cost of 275 dollars. good luck to you in your quest
Old 01-28-2004, 04:15 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
FTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputation
It could also be a loose perfomance chip. If it was chipped, that is.
Old 01-31-2004, 08:49 AM
Thanks for everyones help. yes a tow bill to the dealership. And 235.00 of work for a graqnd total of 275.00. Not a bad bill for a 97 model. It was the transceiver. I want to thank the folks that have made post on this site as i have learned a lot. YES I TOO have blown a sprk plug from my head at 60,000 miles. This is not acceptable and yes FORD should admit they have a problem and fix. it is a 3500.00 Bill. I fought it down to 1300.00 Bill. Thanks for all the info.
Old 12-20-2006, 09:55 PM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
Pats Problem
I have 97 expy with 168000miles, My recent pats issue, couple weeks ago when outdoor temp. was low 20's high teens tried starting ran for 2 sec then died noticed Theft light blinking, cycled key off & on few times than started.When temps in 30 on up no problem. So I purchased 2 keys from dealer less than 18 bucks each with cut. So for kicks tried new kek without programing and it worked, tried 2nd new key same thing. So I determined PATS Module mus be bad. Purchased form Dealer for about $56 bucks, installed and programed, Now waiting for next cold snap.
Any one see this before?
Old 12-21-2006, 12:40 PM
mahause mahause is offline
mahause is starting off with a positive reputation.
When I had this problem it turned out that the module had came out when in my wifes purse. I did not notice the hole on top of the key for a little bit. When I notice this I hound the module in her purse inserted back in the key and it worked again.
Old 12-21-2006, 01:17 PM
Transponder was in key, had to cycle key on & off few times to start
Old 12-21-2006, 01:34 PM
scottspoerry scottspoerry is offline
scottspoerry is starting off with a positive reputation.
Brake Light Switch might be bad? Just curious...how does this factor in?
Old 01-03-2007, 12:31 PM
i was wondering the same thing.
Old 01-03-2007, 12:46 PM
Can't figure out the Brake Switch thing, Im confused??
Old 01-03-2007, 09:08 PM
FTE Herman's Avatar
I know the brake light circuit will disable the transmission shift lever interlock but not the theft circuit. If that light is flashing it is only the PATS system.
Old 01-04-2007, 06:48 AM
fred_79f250 fred_79f250 is offline
fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.
Quote:
Hmmmm - I have a 2000 Expy, and I'm lookin' at the key - nothing in the head of the key - just solid plastic. A module that can fall out??
Old 01-04-2007, 12:08 PM
I don't know if the keys are the same on a 2000. Mine is a 98. On the top of the key is a little black plastic square that popped off. Inside was a white plastic module that came out. I had never noticed this square until it popped off.
99 Navigator stalls and theft light starts blinking while driving yungking Expedition & Navigator 7 09-16-2010 07:11 PM
Theft light and running rough dropper 1997 - 2003 F150 1 02-14-2010 03:36 PM
pats anti theft no start patho44 Explorer, Sport Trac, Mountaineer & Aviator 8 09-19-2008 10:55 AM
Fast Flashing 'Theft' light bla1879 1997 - 2003 F150 6 06-23-2007 11:32 PM
anti theft pats trouble codes patho44 Explorer, Sport Trac, Mountaineer & Aviator 7 03-16-2007 10:21 AM
Tags
2002, 2003, 73, bell, blinking, blinks, displayed, excursion, expedition, flashing, ford, kenne, light, mileage, navigator, start, theft, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
