5w 40 rotella t syn. Is it worth it?
At the Walmart where I purchase my oil and filters they sell rotella t 15w 40 and rotella t synthetic 5w 40, both are deisel rated. The first one, non-synthetic sells for about 6.50. The synthetic, which I am using now sells for about double that. These oil changes are becoming quit expensive. Is syn. something that will extend engine life dramaticly or is it a waste of money?
One of the reasons why I started using syn was because it claims to make cold starts easier. Would I lose the luxury of easy cold starts if I switched to 15w 40 non-syn?
-Steve
-Steve
I have been wondering the exact same thing! I am looking at taking the "plonge" to synthetic. I would like to do the changes myself, but at $12 at gallon ~ $72 + filter per change, jiffy lube says they can due a change in synthetic for around $80-$85. If that's the case, it's not worth my time (AND MESS!) to do it myself!..........Looking forward to comments on this thred!!
(03' F250SD w/ 38K already!, and pull 15-20K lbs. trailer almost daily)
The 5w part will help in extreme cold weather. In MA, you probably should be running 10w-30 in winter anyway.
You will get all kinds of stories, good and bad, from both dino and syn. users, so you will have to read the threads and make up your own mind.
Personally, I'm a dino man, the cheapest that I can find. I also run 15w-40 year 'round. But in Tejas, extreme cold temps are not an issue. If I live in the Great White North, I'd at least run a dino 10w-30 in winter months. If it was in a really cold area (consistent single and negative digits), I might convert and run a 5w-40 syn. in the winter for the cold flow properties.
BTW, for towing above 50*F, Ford recommends 15w-40.
You can easily double you oil change interval with synthetic, and that will make up for the cost. The polymers that are in dino oil, are not in the synthetic, so there is nothing that shears out, so your oil filter stay cleaner. Also synthetic oil contain esters, which a clean out the engine, and b stick the metal surfaces for better oil protection. I would recomend using synthetic oil, the cost is made up for extened oil changes, your engine will last a lot longer, and it will shut up the EPA.
problem is that the recommended service interval will be the same regardless of what type of oil you run. This would matter really while under warranty. I change oil at the recommended interval or more frequently therefore synth would be 2-4x the price for me.
I stick by the same philosphy as jschira.
Yes, and syn. will make your cows give more milk, your cat will stop shedding and will cure baldness.
BTW, that Viagra you're taking? Don't need it with syn. in your truck.
Americans tend to think of things in terms of "good, better, best".
I want to introduce everyone to the concept of "Good Enough".
Is syn. "better" than dino?
Yes.
Is dino "Good Enough" for the vast majority of people?
Yes.
So, my apologies. Run syn. if it makes you feel warm and fuzzy to use "the best", but realize that almost no one will get any practical benefit from syn.
Yes.
Yes.
Beachbumcook
07-16-2011 05:17 PM
BillyBob69
30
01-09-2010 12:52 PM
