Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-25-2004, 08:42 PM
dakota_viking's Avatar
dakota_viking dakota_viking is offline
dakota_viking is starting off with a positive reputation.
Talking Odometer Blackout Problem Fixed!!!
OK campers, I think I figured it out! (Sorry if this gets long...)
I took out my instrument cluster to install my Nu-Image Flame gauges. Since my odometer has been plagued with the famous blackout syndrome, I decided to dive in and see if it could be fixed without giving Ford $375 for a new cluster.
What I found was a cold solder joint. With a couple of minutes using a solder pencil, problem solved! No need to fork over any money to Ford.
Here's how it goes: .
Using a service manual or CD, remove your instrument cluster
If you find a cold solder joint, simply touch it with a hot soldering pencil (NOT A GUN...It's TOO Hot!) and add just a touch of solder.
If all goes well, reverse the process to put it back together.
****IMPORTANT****
If you are not comfortable soldering or getting into electronic boards, you may want to consider finding someone in your area that is. (Maybe a stereo shop) I have been in electronics for several years and was willing to go for it rather than shell out the cash.
Good luck and remember to TAKE YOUR TIME!!!
If you have any questions, just shoot me an e-mail, I may be able to help out.
__________________
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together.
'99 XLT Expedition 4x4 - Black - Triton 5.4L
94 Mustang Coupe
'76 F-250 "Project Copperhead" 460/C-6 (Lots of Rust!)
  #2 (permalink)
Old 01-25-2004, 09:41 PM
who1975 who1975 is offline
who1975 is starting off with a positive reputation.
dakota-viking-
This is an awesome post!!! After reading it, I am going to try to muster enough balls to try to fix mine as well. Thanks again. I will e-mail you if I have any quesitions. Thanks.
Bill
__________________
who1975
Used to own:
'99 Eddie Bauer 5.4L 4x4
Mach Audio with Kicker Comp Sub
NOW OWN:
2005 XLT Supercrew 5.4L 4x4
  #3 (permalink)
Old 01-25-2004, 10:19 PM
tsdrallyer tsdrallyer is offline
tsdrallyer is starting off with a positive reputation.
very good post and one of the best I've seen anywhere. 'Thanks.
__________________
'08 EB,5.4L,4x4,3.73,17" wheels,rear air,HDtow pkg. all options except convenience pkg.
'05 Escape Limited, 4x4, all options, tow pkg.
  #4 (permalink)
Old 01-25-2004, 10:36 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
Sweet! Talk to ken and see if you can get that made into a tech article
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
2002 Dodge Ram
Quote:
Originally Posted by tcbofade
I have no brain
  #5 (permalink)
Old 01-25-2004, 11:40 PM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
Viking- do you mind if I include this in my EOG 2.0?
If so, please email me with your full name, etc. so I can credit you properly.
This is great stuff.
XXL
  #6 (permalink)
Old 01-26-2004, 04:36 PM
KR1's Avatar
KR1 KR1 is offline
KR1 is starting off with a positive reputation.
How hard is it to remove the instrument cluster ???
__________________
99 EXPY EB (2WD) 4.6L, 148K (14mpg).
05 Yamaha FZ6, 600cc... (45mpg)...and its fast!
http://www.ford-trucks.com/forums/pi...pictureid=1746
  #7 (permalink)
Old 01-26-2004, 04:48 PM
KR1,
The cluster is very easy to remove. You have to remove the headlight switch, the cover just above the steering column, and the panel that houses the headlight switch and also goes around the cluster. Once that is out, just remove 4 bolts, 2 connectors and the gear display (just squeeze tabs and remove). With that, the cluster is out of the dash and in your hands.
It took me a total of about 14 minutes and that included disconnecting the battery (do this before you do anything else)
Good luck.
__________________
94 Mustang Coupe
  #8 (permalink)
Old 01-26-2004, 04:54 PM
KR1's Avatar
KR1 KR1 is offline
Thanks, will try it soon. The Odometer always has problems in the summer months, but is OK now.....
__________________
  #9 (permalink)
Old 01-27-2004, 10:21 AM
Well, It's been 3 days and about 50 degrees of temperature difference as well as about 150 miles of driving.
Everything is working perfectly and the odometer has not even blinked once!
I think it's a winner! Good luck to anyone else that tries this. If you have questions, just shoot me an e-mail.
__________________
94 Mustang Coupe
  #10 (permalink)
Old 05-17-2004, 03:03 AM
MacDaddy MacDaddy is offline
MacDaddy is starting off with a positive reputation.
Smile Dakota Viking is THE MAN!!
Well I took the plunge this weekend and decided to pull the cluster out and take a look. My 1999 F150 has had odometer problem since about 50000 miles. Now has 69000 and I was tired of playing hide and go seek with it. Did just as Dakota said. Didn't have the magnifying glass which would have really come in handy but had the wife look at the pins and the picture that Dakota posted and sure enough it was the same one. Took a pencil type soldering iron with a very small tip and just touched pin and put a VERY small amount around the pin and it works like new. Looks odd now to look down and see odometer all lit up. Not a bad job if you take your time and don't get in a hurry. Thanks to Dakota Viking I saved myself about $300 plus from what I have heard. It appears that there are quite a few trucks out there with this problem.
  #11 (permalink)
Old 05-17-2004, 10:46 AM
Glad to be of assistance!
PS. I accept tips at....
Congrats on the fix!
Tim
__________________
94 Mustang Coupe
  #12 (permalink)
Old 07-02-2004, 08:26 AM
jbwash jbwash is offline
jbwash is starting off with a positive reputation.
glad I found this thread. just started having the blackout with my 99 F-150 about a week ago. I know what I'll be doing this weekend. put this thread in my favorites list in case I need to look it up again.
  #13 (permalink)
Old 07-03-2004, 03:14 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.
Great job! I knew someone would finally dig in and try a fix for this. Ive seen many clusters with this problem. Thanks!
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #14 (permalink)
Old 07-04-2004, 10:53 PM
rebel_gtc rebel_gtc is offline
rebel_gtc is starting off with a positive reputation.
Nice one dakota_viking!!!!
  #15 (permalink)
Old 07-05-2004, 09:41 PM
maverick5 maverick5 is offline
maverick5 is starting off with a positive reputation.
Question odometer blackout - any sounds?
Am I glad I discovered this thread! My 2000 F150 has the same odometer blackout problem. When I turn the key and stop before actually starting, wait for the odometer light to finally come on - theres a low boom-thud sound coming from directly behind the dash. Anyone else discovered this? It only happens when the odometer lights up. Any ideas?
Cheers!
Tags
150 , 2000 , 2001 , blackout , blank , electronic , erratic , expedition , f150 , ford , harley , odometer , problem , repair , speedometer , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
