Odometer Blackout Problem Fixed!!! - Page 3 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
  #31
Old 10-06-2004, 08:42 PM
nstyle nstyle is offline
nstyle is starting off with a positive reputation.
Thanks all for the excellent description for removing the headlight controls, and especially how to resolder the pin for the odometer light.
This has been a major annoyance for me and is a relief to know that it is now fixed. I took my time and the entire process took about 1:30 minutes from start to cleaned up finish.
I did make the mistake when removing the dash console pieces of unscrewing some of the hex 15 screws. I now realize that the only gold hex 15 screws that need to be removed are on the back side of the instrument cluster to access the board.
Thanks again everyone.
  #32
Old 10-16-2004, 02:33 AM
ssKable ssKable is offline
ssKable is starting off with a positive reputation.
Awsome post I have had this problem for about 6 months now on my 99 and I am going to attack it tomorrow, this problem seems VERY similar to another problem I'v had with my truck for about a year now. I still have the stock stereo and the display went out on it, at first it was doing the same thing the odometer is now if it went out I could hit it and it would come back on. Has anyone else had this same problem and been able to fix it yet? I think I will take the stereo appart tomorrow and check for some cold solder joints and see if that is the problem, if so I will let you guys know.
Also since you have to remove the headlamp switch to get the panel off it brings up a question I have been wondering for a long time. Is there a way to somhow modify that switch so you can drive with your foglights on withought your headlights? thanks, and again VERY VERY AWSOME post!!!!!!!!
  #33
Old 10-16-2004, 07:45 AM
blwilli blwilli is offline
blwilli is starting off with a positive reputation.
be sure to use rosin flux core Eutectic solder (63/37 tin lead) and clean off the flux with an acid brush and isopropyl alcohol to prevent corrosion.
  #34
Old 10-16-2004, 08:35 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
I have had the disply problem in other ford radios, was told it was a light bulb? Cannot confirm because I did not take apart my self.
  #35
Old 10-16-2004, 04:09 PM
So, is there a certian type of soldering pencil or just the pencil style of soldering iron that I need to use? any specific wattage?
  #36
Old 10-18-2004, 07:28 AM
dakota_viking's Avatar
dakota_viking dakota_viking is offline
dakota_viking is gaining momentum as a positive member of FTE.dakota_viking is gaining momentum as a positive member of FTE.
Sorry for the delay on an answer, the weekend you know.
A standard soldering pencil/iron will work. Just do not leave it on the contacts any longer than necessary.
Good luck with it!
Tim
  #37
Old 10-24-2004, 02:11 PM
TCExp's Avatar
TCExp TCExp is offline
TCExp is starting off with a positive reputation.
Great post, I am one of the many with the disappearing odometer.
  #38
Old 12-04-2004, 12:52 PM
GT350Mike's Avatar
GT350Mike GT350Mike is offline
GT350Mike is starting off with a positive reputation.
GREAT LINK!
Thanks!!!
  #39
Old 01-18-2005, 11:47 AM
jon_bauman jon_bauman is offline
jon_bauman is starting off with a positive reputation.
Awesome bit of information! My '99 has had this as an intermittent problem for at least a year now. Finally I can fix it!
I wonder if this could also be the problem with my radio? I have the stock head unit and about 5 months ago it went blank and has never come back.
  #40
Old 01-18-2005, 12:12 PM
saltzy saltzy is offline
saltzy is starting off with a positive reputation.
There was a thread about the radio as well. Do a search, but it gave steps to fixing it as this thread does for the odo.
  #41
Old 01-18-2005, 01:31 PM
Bedasi Bedasi is offline
Bedasi is starting off with a positive reputation.
Smile Great Fix
This is the best thing going. I thought I had to just live with it, but fixing it took 20 minutes.
Thanks!
  #42
Old 01-18-2005, 05:11 PM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE.aerocolorado is gaining momentum as a positive member of FTE.
It's the same dang problem with the radio display, bad solder joints. Takes maybe 30 mintues to fix the radio but you need to know which contacts to address. Check the Tech Articles section. Did Ford invest in that cold process soldering iron I keep seeing advertised on TV?
  #43
Old 01-30-2005, 08:05 AM
jmac2725 jmac2725 is offline
jmac2725 is starting off with a positive reputation.
I have a '98, replaced the bulbs (5) but the panel does not appear to be as bright as it could be. The bulbs I replaced were in balck housings, are there others that Illuminate the panel? Also, the radio has dim lights except for the LED/CLOCK, are there bulbs that can be replaced and if so, how do you remove the face plate?
JM
  #44
Old 03-16-2005, 02:06 PM
bandito20 bandito20 is offline
bandito20 is starting off with a positive reputation.
97 instrument cluster panel
viking,
I dove into the instrument cluster panel and I believe that there is a difference in the earlier model expeditions. I could not find a cold solder point anywhere. My panel went out all of a sudden and has not come back on. Also, the tone that reminds you that you left the lights on is not working either. I checked the fuses and the switch and both seem to be working fine. Could the instrument panel be responsible for the tone also?
  #45
Old 04-25-2005, 02:24 PM
fepo2003 fepo2003 is offline
fepo2003 is starting off with a positive reputation.
Service wanted...
Man I wish I was electrically inclined to attempt this myself. Anyone know of any shops or private parties in Orlando that would do this for $100? Has anyone got a dealer quote on replacement? Is the part $375? Or does that include installation? If anyone in O<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:City w:st=[/img]<?xml:namespace prefix = st1 ns = " /><st1:City w:st="on">rlando</st1:City> has successfully repaired this and wants a nice crisp $100 bill in their pocket please contact me.
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
Have you looked under the front of your 2011 EB yet? jimmyb08SD EcoBoost (all engine sizes) 11 04-25-2011 10:30 PM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 12:02 PM
Pics of new fox dual stabilizers divedeep1 1999 to 2016 Super Duty 9 05-04-2010 01:47 PM
Some pictures of the Body Work Red Ford Truck Ontario Chapter 27 07-26-2009 08:12 AM
Tags
150, 2000, 2001, blackout, blank, electronic, erratic, expedition, f150, ford, harley, odometer, problem, repair, speedometer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
