4.2 fuel pressure - Ford Truck Enthusiasts Forums
4.2 fuel pressure
Old 01-25-2004, 06:06 PM
iahte my ford4.2 iahte my ford4.2 is offline
iahte my ford4.2 is starting off with a positive reputation.
4.2 fuel pressure
i did a fuel pressure test on my 97 f150 4.2 everything is within specs except when i remove the vacume line from the presure regulator the presure didnt increase like the book said it should does this tell me my regulator is bad?
Old 01-25-2004, 09:41 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Did the line have vacuum on it?
What was the pressure that you were getting?
Old 01-26-2004, 06:56 AM
the line had vacum i was getting between 30 and 40 psi
Old 01-26-2004, 08:12 AM
LxMan1's Avatar
It should be about 32 psi with vacuum and 40 or so without.
If it sin't changing and you have a contant 40psi, then I would suspect the regulator. Did any gas come out of the vacuum port on the regulator?
Old 01-26-2004, 08:39 AM
no gas came out that i noticed thank you for the response
Old 01-29-2004, 01:01 PM
4.2 fuel presure
i changed my pressure regulator it fixed the stumble and the hard starts for 1 day now its doint it again sometimes it surges when i take off it acts like it is running out of fuel but it takes off about a secong later
Old 01-29-2004, 06:00 PM
LxMan1's Avatar
Clean the MAF. Also, check the TPS sensor, it could have a bad spot in it.
Jimmy
Old 01-29-2004, 10:32 PM
tps is a week old cleaned the maf 2 weeks ago
Fuel pressure regulator question LaReko 1997 - 2003 F150 4 01-13-2013 11:55 PM
93 F150 fuel problems CrazyMiracleMan 1987 - 1996 F150 & Larger F-Series Trucks 13 10-16-2012 04:35 PM
low fuel presure eckart Ranger & B-Series 4 07-01-2012 09:56 PM
Fuel Reg O-Ring Kit smokersteve 6.0L Power Stroke Diesel 43 02-24-2011 10:36 AM
Gurgling Noise from fuel tank ? kye 1997 - 2003 F150 2 10-23-2008 12:54 PM
Tags
150, 2002, 42, 97, 99, f150, ford, fuel, location, motor, port, pressure, regulator, test, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
