Had a good day of progress on the old 3-speed tranny... two steps forward, one step back sort of stuff.
I'm actually getting very close to getting it back together, just need to put the countershaft back in. However, I did have a few questions that would be great to get some clarification (peace of mind) on:
1.) Is the amount of space as indicated by this screwdriver between the large snap ring and the tranny case normal?
http://www.guessasketch.com/73eb/DX3500_0611.JPG
I'm sure the bearing is in the correct spot on the shaft as the small snap ring is installed correctly... but I don't recall there being any space between the large snap ring and the case way back when I started. It's almost as if the output shaft isn't mated completely with the input shaft. I'm sure there aren't any roller bearings out of place between the shafts because it wouldn't have gone together so easily, and I think the gap would be larger if that was the case. Any info on this would be appreciated.
2.) I noticed a bit of play (about 1/16 to 1/8", see pics) at the end of the input shaft after the bearing was in place. It seems the play is in the roller bearings themselves. Is this too much play? Am I asking for trouble putting this back together without replacing them?
http://www.guessasketch.com/73eb/DX3500_0619.JPG
http://www.guessasketch.com/73eb/DX3500_0618.JPG
Thanks for your help!
Carl
