Transmission Removal Problem
Hey guys, I have a 96 F-150 with the 4.9l and manual 5 speed. I am in the process of removing the tranny to replace the slave cylinder and clutch. The problem I am having is that with everything disconnected and all the bolts out of the bellhousing, the transmission will not budge! Any ideas? After not working on my own vehicles for a year or so, I am starting to remember why i like working on jets better...... No RUST!!!
What we did was put the clutch line back on and pushed in on the clutch to drive them appart. While doing this, we pried with a screwdriver. Don't worry, sometimes they just are tight with any engine/tranny. Be carefull not to put to much pressure, because if it pops, you don't want it coming off and resting on the PP. Good luck.
on
1 Post
Re: Transmission Removal Problem
I just did this over the weekend. Jack the back of the engine, with a block of wood under the oil pan. this will raise it with the transmission to help clear the trans cross memeber. After I did that just pryed my trans away from the engine and it slowly moved away til it came apart. Remember to jack the engine when you put it back together. Fred
