Throw-out bearing
Throw-out bearing
I just installed a new clutch and new TO bearing. Problem is the new TO bearing screeches real bad. Everyone is telling me that the bearing is sealed and there isn't anything to grease upon installation.
1. Did I miss a step when installing the TO bearing?
2. Has anyone had a bad bearing, new out-of-box failure?
PS I'm looking for reasons not to pull the transmission. Please help me find one. (lol)
I had this problem when I reinstalled my used clutch after some work. I had a loud chirp that got worse when I pushed in the clutch. The only thing I replaced on the clutch was the TO bearing. I just a djust the clutch out alot till engage ment was a couple of inches on the pedal. The sound went away. The I readjusted the clutch months later to were I liked it.
Did you use an alignment tool on when you reassembled. The one they give you with the clutch kit is crap? Also did you resurface the flywheel? If not you may be hearing the clutch wearing on the old groves the old clutch made.
Yes, I had the flywheel resurfaced and balanced with the engine. I haven't spent any time adjusting the clutch. I just hooked it up and got it close. (the noise scared me. I don't want to pull the tranny.) I'll try adjusting the clutch in some more.
Any special grease on the pilot?
PS To align the clutch, I borrowed a piece of the drive shaft from the machine shop that rebuilt the engine. Worked slick.
well, i know what you are talking about, my truck is doin the exact same thing. i just had a BRAND NEW clutch put in at mr transmission about a month or two ago and when i got it back from the exhaust place, i started having a loud noise. also when i got into high rpm's it would sound like a bolt raddeling in a coffee can. i just took it back into the shop yesterday. another thing that happened with mine was after it would heat up, the clutch would stick or when it was fully depressed it would creep a little bit, like i was letting off the clutch. hopefully i will find out what wrong with my truck today. ill post as soon as i find out what my problem was. hope i helped.
One of the problems with these old trucks is that the flywheel has been resurface too many times and it moves eveything foreward. I have had to make a longer clutch adjuster on several just to get the clutch adjustment so you could put it in gear. Now this is somewhat of a problem because now the release arm is going well past the travel limit it was designed for and some binding and noises may result.
After further investigation...
The screeching noise happens when I RELEASE the clutch. (sorry for the misinformation earlier)
When the Clutch starts to contact the pressure plate and fly wheel, the clutch starts to grip and makes the moise for a few seconds. Almost like it's out of aignment as it releases.
Planning to work on it tonight, when I have some help.
PS Thanks for all the help. I'll let you know what I find.
