Idler Puley on the belt tensioner bad! Help !
Old 01-22-2004, 10:34 AM
F1FiddyGuy's Avatar
F1FiddyGuy
F1FiddyGuy is offline
Question Idler Puley on the belt tensioner bad! Help !
Hey All~
I was driving along yesterday, and all of the sudden, i hear a horrible grinding sound, so i pull over and look under the hood...my serpentine is torn to shreads! I figured easy fix... upon closer inspection i found that the idler pulley on the tensioner looks like the bearing blew, it looks like crap. It's all kittywampus.
Has anyone replaced a pulley and/or a serpentine belt on a '97 or similar 4.2? Is there anything I should know? Napa has the pulley fdor $18 and the belt for $33, i figure it should be an easy fix, whenever i get around to it.
Any suggestions?
Thanks in advance for any help...if anyone has had it done at a shop or ford, how much was it? I hate fighting with seprentine belts, would shop work be worth it? Probably not...
Thanks again
Ryan
Old 01-22-2004, 12:58 PM
true4.2's Avatar
true4.2
true4.2 is offline
Have a nice belt tensioner ready!
Old 01-22-2004, 09:22 PM
F1FiddyGuy's Avatar
F1FiddyGuy
True 4.2, what do you mean? Are you saying i can't just buy the idler pulley for the tensioner? Or do you mean it's gonna be a pain to do? Thanks!
Old 01-25-2004, 08:27 AM
F1FiddyGuy's Avatar
F1FiddyGuy
Hey All~
So, i switched the idler pulley on the tensioner and the serpintine belt. I was worrying about nothing, I think it was the easiest repair work I've ever done! ABout $55 and a half hour later, the job was done. If anyone has to do it, just know that the thread on the retaining bolt for the pulley is reverse thread. Well, hope it'll help someone. P.S. Does anyone know a 4.2 with 8 pulleys? Apparently some have 8 and some have 7, i was just curious.
~Ryan
Old 01-25-2004, 09:32 AM
true4.2's Avatar
true4.2
true4.2 is offline
Now you're confusing me. 8 and 7 pulleys? Wierd
Old 01-25-2004, 09:03 PM
plourde2002's Avatar
plourde2002
plourde2002 is offline
My guess is your extra pulley is air conditioning? Did you check the other idler pulleys? My truck had 3 idlers, and two of em went bad at once...
Old 01-25-2004, 09:59 PM
F1FiddyGuy's Avatar
F1FiddyGuy
I have 7 pulleys, and that's including the AC pulley, 2 idlers, alternator, crankshaft, water pump, and fan. I go through NAPA autoparts, and they had 2 different stock belts for a '97 F-150 with a 4.2. One was with A/C 7 pulley system the other with A/C 8 pulley system, I called Ford and they offered the same options. According to plourde2002, the extra pulley may be a third idler pulley. It's wierd they're all not the same. I guess i could just ask ford. Well, whatever the case if you ever have to replace a serpentine i your 4.2, know how many pulleys you have if you have A/C. Talk to ya'll later.
MichaelWetherholt
1997 - 2003 F150
06-30-2016 09:24 PM
texansport
2004 - 2008 F150
09-05-2015 08:42 PM
r___r
31
02-09-2014 08:49 PM
bluemtn95ford
25
02-10-2013 11:30 PM
tored1971
09-17-2009 09:07 AM
Quick Reply: Idler Puley on the belt tensioner bad! Help !
