i need heat!!
01-20-2004, 10:31 PM
on
i need heat!!
i have a 93 E150, i replaced the heater core, remove the two lines going to the rear core, replaced the hot/cold valve connected to a vacuum line and the switch inside the cab.replaced thermostat and still i dont have heat. radiator and all the rubber hoses are HOT. fan blower works. anybody out there got some idea? thanks guys...
01-20-2004, 11:11 PM
on
No heat in the front? I'm not familiar with the 92 and newer vans. Maybe it has a blend door that's broken or stuck. If both hoses going to the heater core are hot and it's blowing cold air, I don't see what else it could be.
01-20-2004, 11:15 PM
on
yes, a/c works just fine.
01-21-2004, 04:56 PM
on
HEAT!
im have same problem.....you seem to know about fords you know anything about maybe a valve for heat? my antifreeze is good core is good but blowing cool air
thanks in advance
Joe
01-21-2004, 09:23 PM
on
joe, the valve is inline the small hose on the left top side facing the van. it's about 2inches in diameter. can miss it cause it is cinnected to a vacuum(tiny hose). you can check it by moving the hot/cold switch inside the van.you might need 2 person.
