Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > New Hampshire Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
  #1 (permalink)
Old 01-21-2004, 09:39 AM
roadwolf roadwolf is offline
Garage is empty, add now
roadwolf is starting off with a positive reputation.
Unhappy no brakes on f350
have replaced vacuum booster and master cylinder and pedal still goes to the floor even after being bleed 3 times.What am I missing?
  #2 (permalink)
Old 01-27-2004, 05:47 PM
ATC_250SX ATC_250SX is offline
ATC_250SX is starting off with a positive reputation.
Do you gots a leaky weel cylinder? try bleading backwards, from wheel up i had to to that to my clutch in my old blazer once.
  #3 (permalink)
Old 01-31-2004, 11:01 AM
etsd etsd is offline
etsd is starting off with a positive reputation.
Hey Roadwolf,
Did you find the problem? I'm having the same problem on my '95 F350. I suspect it has something to do with the accumulator that is mounted on the frame a little more than halfway back. I'm not sure if it gets bled by normal bleeding methods.
Please let me know if you got yours fixed.
Tags
brakes, f350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
