You want the coil connected to the crank and run position with 12v. And then connected through a resistor for the run position. The factory harness has the resistor built in.
If the coil is staying hot with the key off, you have something connected wrong or the ign switch is bad... Need some more info.
Most of the one wire alternator setups are based off of a Delco style alternator. You should be able to run the wire directly to the positive battery terminal (Through the ammeter if you want it to function).
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
