Removal of stock radio on 04 F150
I just did it today
open the ashtray
pull on the bezel that surrounds the headunit and HVAC controls, starting from the bottom near the ahstray
6 clips - 2 at bottom near ashtray, 2 half way up, and 2 at the top where it radius's over.
short quick tugs and it will pop out. working from bottom to top
unplug the "airbag off" light's wire harness, and set the bezel down toward the shifter ( center console) with HVAC connectors still attached
then the 1.5 DIN headunit comes out with (4) 7mm screws
good luck
open the ashtray
good luck
IT'S EASY!!!!
Kdog250.....
I did it last Friday......and it's a piece of cake. I installed the TERK "Commander", XM Sateliite Radio in my new F-150, and located the control unit in the ashtray housing. It open and closes just as if the ashtray were in place, and looks VERY "factory" installed....as ALL wires and other components are out of sight.
To find out more about removing the factory dash trim, radio, etc., this I STRONGLY suggest you click on the link that lariat F150 provided above. I did, and it was IMMENSELY helpful.
If you or anybody have any questions about how I mounted my XM Commander Control Unit in the ashtray receptacle of my truck, please post them here, and I will answer them as fast as possible.....
Good luck with your install!!!
Keep in mind that if you are installing an aftermarket deck, you will need the wiring harness. I tried to get one here in Cow Hamphire last week and no one carries the one for the 04 (evidently it's different than the 03). I had to order one off the net which does cause a delay in the process.
www.instaldr.com
Is a good place to start, I didnt see any thing newer than 2000, and I dont know if the dashes are the same
drz400dp
10-03-2004 06:16 PM
gward
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-09-2004 10:08 PM
