460 Block casting numbers
I was looking at a 460 block, casting # is D9TE-AB. The seller claims it is an SVO block. I was not able to get too much info regarding this casting number but best I could tell it's an early 90's regular 460 block. Does anyone know of a resource for checking SVO block numbers?
I know the T stands for Truck.
But when it comes to engine class the usually always keep the *original* dedication.
The 460 wasn't originally made for the truck it was designed for the Lincoln, thus the V.
The 352 was designed for a full-size car = ID is O.
Was the 360 designed for a truck ?
as was the 361,391,
Yes ? That would make it a C9TE-A
If The 289 was designed for a Fairlane > ID is an A
If The 302 was designed for a Fullsize Ford ID would be an O.
This is why I find the thought of the 460 having a T as the car line
character as not correct.
as was the 361,391,
Mil1ion
I was not dissing you. Take it easy.
I as well know the 460 did not start life as a truck engine.
But the D9TE block casting was for the external balanced engine used in the 79 up 460 trucks and vans. And greenhighboy threw in a couple more truck applications.
I will also add, there appears to not be a lick of difference between the V Lincoln casting and this one. I have one of each for comparison.
jacob_9249
07-26-2008 08:04 AM
