2.9 head bolt torque ? - Ford Truck Enthusiasts Forums
Old 01-18-2004, 07:24 PM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
Question 2.9 head bolt torque ?
I have a quick question about the torque sequence on a 2.9. In the book I am using it says to torque in 4 steps. 1st step 22 ft lbs. 2nd step 51-55 ft. lbs. 3rd step wait five minutes. 4th step turn 90 degrees. It is the fourth step that I am confused about because to me it is not very specific. Maybe if I didn't think so hard I would just tighten them up another 90 degrees but I want to make sure that in fact I am suppose to tighten them. Any body have any input on this. Thanks.
Old 01-18-2004, 11:33 PM
jandjstewart jandjstewart is offline
jandjstewart is starting off with a positive reputation.
the say 90 degrees because a strech bolt is used and an acurate torque wont be achieve on them but it will end up right around 100 ft lbs
Old 01-19-2004, 08:28 PM
Boss_358's Avatar
It also says that new head bolts are required but I had already purchased new head bolts just in case.
Old 01-20-2004, 04:42 PM
snwcmpr snwcmpr is offline
snwcmpr is starting off with a positive reputation.
I just did that on my truck, and it was recommended by my mechanic that I use a half inch drive socket instead of a 3/8" drive socket due to the amount of torque that will result. He said the smaller socket most likely will break.
Ken
Old 01-20-2004, 08:11 PM
Boss_358's Avatar
The head bolts are Torx. Do the same rules apply?
Old 01-23-2004, 03:44 PM
I don't know, but I do know the torque will exceed 100 ft lbs.
Old 01-23-2004, 11:17 PM
capridude capridude is offline
capridude is starting off with a positive reputation.
I had never used "torque-to-yield" head bolts
before...... torquing that last 90 degrees was
WEIRD because the bolts feel like they are going
to snap off!
4.0 OHV engine experts please help - quick question about connecting rod torque jimkari Explorer, Sport Trac, Mountaineer & Aviator 6 03-21-2016 06:52 AM
'05 F350 Ball Joints jencksh 6.0L Power Stroke Diesel 1 02-18-2014 09:43 AM
HELP! Crankshaft. deputydog03 1997 - 2003 F150 3 11-22-2013 01:59 PM
Inspected/Repacked/Replaced Wheel Bearings... 17 inch lbs 99ExpyProblems 6.0L Power Stroke Diesel 10 10-04-2013 02:55 PM
Wheel Bearing Adjustment E150 1968-2013 Full Size Vans 6 10-03-2008 12:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
29, 30, 90, bolt, bronco, degree, engine, ford, gasket, head, sequence, torque, turn, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
