help!!!
Old 01-18-2004, 12:00 AM
mikemhp's Avatar
mikemhp
mikemhp is offline
help!!!
i have narrowed my truck's problem down to the following:
egr vacuum regulator; pcv valve; or maf sensor....
i got no resistance from the egr vac. reg. (short), and i think i have a leak or faulty vacuum hose near the egr. right after i shut the engine off, i can hear a "pppssssssssssss" (kind of like letting the air out of a tire, but not as loud) right in the area of the egr vac reg... or slightly behind the egr valve itself.
i don't know exactly how to check and/or verify the vacuum hoses to determine if they are working right. i do not have a vacuum pump or tester for this....
what can i do to try to fix this myself???? i'm getting closer to finding out the exact problem...
any help would be greatly appreciated- please see first post=
https://www.ford-trucks.com/forums/s...hreadid=193431
Old 01-18-2004, 12:56 AM
gkbid's Avatar
gkbid
gkbid is offline
Check out this thread, it you should find it helpful...
https://www.ford-trucks.com/forums/s...hreadid=170847
Tkc432
18
08-30-2017 09:10 AM
GeneGregory
16
11-17-2016 12:19 PM
lanier1974
04-07-2016 03:14 PM
mse871859949
06-15-2014 11:52 PM
firewood truck
46
05-31-2012 08:41 PM
Quick Reply: help!!!
