Hi compression pistons 400 ci?? - Ford Truck Enthusiasts Forums
Old 01-17-2004, 09:16 PM
400 Ford 400 Ford is offline
400 Ford is starting off with a positive reputation.
Lightbulb Hi compression pistons 400 ci??
I am looking for high compression pistons for my '79 400 cui. F150. I have contacted parts stores and several online engine parts companies with no luck. Can anyone tell me where I can find higher compression pistons for this engine?
The stock pistons are very low compression. When I rebuild I want to give this engine some more horses under the hood and hopefully better mpg (currently get 9 mpg without a heavey foot or a load).
Old 01-17-2004, 11:44 PM
f100guy f100guy is offline
f100guy is starting off with a positive reputation.
try a machine shop
Old 01-17-2004, 11:54 PM
1976BeaterF150's Avatar
1976BeaterF150 1976BeaterF150 is offline
1976BeaterF150 is starting off with a positive reputation.
you can always deck the heads alittle, give you some compression there, pending the heads you might be able to squeeze 1.0 out of them... I know that JE Pistons makes custom anything.
Old 01-18-2004, 01:50 AM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
You might have better luck with 335 engines in the 335 engine forum.
No, there aren't and high compression pistons available for the 400.
Old 01-18-2004, 07:33 AM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
A cheaper way than custom made pistons is to have the rod ends bushed to fit 351 Cleveland pistons. Lots of those to choose from.
Nathan
Old 01-18-2004, 10:49 AM
skuteman skuteman is offline
skuteman is starting off with a positive reputation.
You really don't need anything greater than 9 : 1 as when you finish your head work your probably going to be sitting on 10 : 1 or a little greater which is going require you to use 93 octane gas and you'll be getting about 7 mpg. Now, unless you're wealthy, you are going to be spending A LOT of money on gas. Most people don't factor this into their buildup equation until after the engine is already built then they realize they can't afford the Gas......you've got a 400 HP truck that is Too expensive to Drive on a regular basis..........s.kuteman
Old 01-18-2004, 06:04 PM
freak98's Avatar
freak98 freak98 is offline
freak98 is starting off with a positive reputation.
400 Ford,I used 351C piston's in my 400 and had the small end's bushed.I'm at 10 to 1 and the piston's ard still .025 in the hole.If I zero decked the block and shaved the head's I could get almost 12 to 1.
Old 01-19-2004, 12:03 AM
Sanders's Avatar
Sanders Sanders is offline
Sanders is starting off with a positive reputation.
High compression pistons do exist for the 400M. I have a set in my LTD. The are very hard to find though. They were made by Dynagear and they are bored thirty over only cost me 124 dollars. I don't know if I can post phone numbers on here but if anyone is interested where I got them let me know.
Sanders
Old 01-19-2004, 12:36 AM
Sanders's Avatar
Skuteman is right about mpg. I zero decked my block and milled my heads and installed a set of flat tops. I really don't know what my compression level is, but it has to have 93 octane, any less and it knocks and pings. I get about 6-8 mpg around town and on the interstate aound 18-20. The bright side is that is a strong motor that pulls like a frieght train. Sounds mean too, it has true duals with no cats and dual glass packs.
Anyway the part number for flat top 400 pistons is 1282P. I am going to call the parts store where I got mine and see if they have any more. I let you know.
Sanders
Old 01-19-2004, 01:42 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
You may be able to find a few sets of the flat top pistons on eBay. Distributors do not have them because they are no longer manufactured.
Ertel #1282P
Ohio Piston #1282P
BADGER # 40010F
There are a LOT of threads on this subject here if you use the search function.
Old 01-19-2004, 01:56 AM
Matts72's Avatar
None on Ebay right now.
Ok I just found some, they are $54 a set of 8, the 1971-2 8.4:1 compression pistons, they are stock replacements, the bidding ends in 8 hours, but I am gonna post the contact info, they have 5 pallets of them, and nobody has bid on them, I am sure they will relist.
1-800-792-9984 toll free from Maddog Racing. Mon-Fri 8-5 eastern.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2453454000
these ones are 4.060" bore
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454933415
Old 01-19-2004, 02:01 AM
Torque1st's Avatar
Posting Legend
MotorHaven will not carry engine parts. It may take a while to see them on eBay, you will need patience.
Old 01-19-2004, 12:43 PM
kkmart kkmart is offline
kkmart is starting off with a positive reputation.
probe industries has flat top pistons to fit the 400
probeindustries.com
I looked @ the pistons on ebay that you linked and those are dish pistons not flat tops
Old 01-19-2004, 04:48 PM
66ford400 66ford400 is offline
66ford400 is starting off with a positive reputation.
I bought my flat tops off ebay. There made by badger. I am getting about 9.6:1 out of them. The guys has alot. He sells them on Ebay all the time. everything from stock bore to .60 over
Old 01-19-2004, 08:03 PM
Torque1st's Avatar
Posting Legend
Maybe the guys here can email you for his contact information. He may have bought the remains of that last production run before Ertel closed their doors. When I talked to them a year or so ago just b4 they closed they had about 100 sets available. They just put different labels on the boxes, the pistons are the same.
360 vs. 390....piston talk! Fellenz 1961 - 1966 F-100 & Larger F-Series Trucks 23 12-08-2014 05:51 PM
Do 429 Cobrajet pistons have higher compression height than 429 thunderjet (std) 1972 Ford Thunderbird 429 V8 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 12-19-2008 06:42 PM
cc and compression info Badger Pistons IHATERUST 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 03-08-2006 12:48 AM
79 400 Compression Ratio Trivia smoulding 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 02-04-2006 01:57 AM
Cleveland pistons in 400 GrayGhost351 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 12-27-2005 10:02 PM
Tags
1160, 400, 400ci, 400m, ci, compression, engines, ford, high, means, photos, piston, pistons, silvolite, stock, z3436
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
