Clark overdrive?
For sure it's not anything that's been discussed here. It's a box from a medium duty driveline not a light duty. It could be almost anything. There's got to be some sort of a casting/foundry ID on the gear case. See if you can find that info. For sure it is easily rebuildable, trannies in that size range always are.
I have all you need to know! Your post got my curiosity going, so I started yahoo! searching. Here is what I found. The model is 250v-18. It was made for ford gas engines and supplied to ford. Here is the link that has the info: http://www.roadranger.com/csee/Mungo...t0069-1001.pdf
The table is on page 3. I don't know if these guys can help you ( or were you just curious?) but it seems like a good place to start.
Good luck, and keep the old truck going! Ted
THIS IS A LINK FOR THE TRANSMISSION I THINK YOU HAVE? I ALSO HAVE THE SAME TRANSMISSION COUPLED TO A 292- V8 FROM A 1961 F600 TRUCK, http://truckpartsinventory.com/porta.../28-6/20449678
sorry about caps... please i am not trying to hijack a thread but the same questions you are asking , i have the same ones... so may i cut in? for some additional inquires? can we confirm that this is a clark 250 (250v-18?) and is it for sure an overdrive? i have not detached the trans from the bell housig yet to find out for myself... i also have the same casting number that you have 224716 on the main housing all cast iron and 5 gears forward (shifter **** is layed out like this left side to right side(2-3-4-5-r-1) but my trans has the pto shaft installed on the right side and a large square cover on the opposite left side this engine and trans came out of a dump truck i plan to remove the pto and do need a cover plate or a picture of one so i can fabricate and also a source for seals and parts, thanks for this thread i hope i helped and i hope you can help also. (mark s.)
MAN KAT1
WTB - Ford Trucks & other vehicles
09-10-2015 11:43 AM
cletusclark
05-18-2013 05:13 PM
nobull4x4
12-07-2004 03:48 PM
