turn signal change out
Old 01-17-2004, 05:53 PM
dangrimsley's Avatar
dangrimsley
dangrimsley is offline
Question turn signal change out
Having some problems with my turn signal switch , I got a new one and was just wondering if anyone has any input on how hard it is to swap this out and if anyone knows where to get any online instructions or guides to kind of help out?
1997 f150
4x4 Lariat
thanks in advance!
Old 01-17-2004, 07:04 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
The switch is easy to replace. The steering wheel doesn't have to be removed.
First you remove the small cover between the steering column and the instrument cluster. It just pulls off. Next you unscrew the tilt column lever. After that you remove the 3 screws that hold the upper and lower steering column covers and remove the lower cover. With the lower cover removed you can remove the ignition lock cylinder. To do that you turn the key to the run position and then with a small pick or screwdriver or nail you push in the "button" that holds the lock cylinder in. It is on the lower side of the lock cylinder housing. It's easier to see that for me to describe. Then you remove the top cover. With the covers off you can now see the multifunction switch. There are 2 connectors on the back of it and 2 Torx head screws on the side where the signal light lever is. Remove the screws and connectors and the switch pulls straight off. Like the manual says....reassemble in reverse order.
Old 01-18-2004, 04:32 PM
dangrimsley
thanks!.. I will give it a try.
Old 01-19-2004, 11:55 AM
dangrimsley
Thanks dave! Made the swap today using your instructions ,,, piece of cake.
Old 01-19-2004, 06:03 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
You're welcome
Good to hear that you got it fixed.
Old 10-21-2010, 06:28 AM
d5332's Avatar
d5332
d5332 is offline
Hi, if you folks don't mind, may I confirm confirm one last time that its my sitch that its bad.
My left turn signal clicks at a faster pace when I engage it and it also click oddly when I turn the Hazards option on....when the hazards are on one does not touch the signals switch.
Given that the left turn singal is overall bad, is the switch the culprit?
Thank you......98 F250 Light Duty
Old 10-21-2010, 08:18 AM
d5332's Avatar
d5332
d5332 is offline
NEVERMIND....The switch is one in the same, hazards and turn signals...
Old 10-21-2010, 09:37 PM
Fox Fader's Avatar
Fox Fader
Fox Fader is offline
Ford's multi-function switch has a short life, /some. I've had to change a couple in the past, Explorer, E-150. Simple and inexpensive though.
Old 10-22-2010, 11:29 AM
minitrk's Avatar
minitrk
minitrk is offline
First off check for a burnt out bulb
Old 10-22-2010, 03:28 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Definitely check the bulb, fast clicking with no light is usually a bad bulb filament. The MFS problems usually show up in the windshield wipers not working right or the headlights going out when put on bright.
Old 10-23-2010, 08:40 PM
d5332's Avatar
d5332
d5332 is offline
I checked all of the bulbs, no bulbs are out but the left turn signal still flickers faster than the right one....
Turn signals still work, just that the left is diff than the right,....really annoying but I am just going to leave it like that until the switch brakes completely....
Old 01-27-2011, 06:26 AM
d5332's Avatar
d5332
d5332 is offline
FYI....My turn signal switch was resolved by adding an extra ground wire to the lighting system....
I added an additional ground to one of the break lights....that fixed the turn signal switch problem.
Old 04-11-2011, 10:48 AM
Myfirstnewtruck's Avatar
Myfirstnewtruck
Myfirstnewtruck is offline
I dont think its my turn signal switch but can I get some help. My turn signals all of the sudden quit working. The wipers and the Hazard lights still work. Would the a burned out bulb cause both signals not to work?
Old 03-26-2013, 04:20 PM
chuckbeener's Avatar
chuckbeener
chuckbeener is offline
got some turn signal issues of my own here. they dont work unless i push the steering wheel all the way up. my hazards work and if i get on the brakes and almost turn the blinkers on and let off and almost turn them on again and let off i can fake the signal. 2002 f-150 4.6L supercrew 2wd
phillips91
General Automotive Discussion
04-21-2020 11:13 PM
gogoat
12-11-2016 01:09 PM
ozzy460
06-21-2016 06:24 PM
Desarata
02-11-2014 08:50 PM
sigtauenus
Electrical Systems/Wiring
07-23-2006 03:30 AM
Quick Reply: turn signal change out
