I'm doing a 351M to a 460 swap and I need to know what brackets I need for the alternator and A/C. Does anyone know? Or even know where I can find them?
just from visiting this forum it sounds like the brackets from an E350 van are the way to go. seems that they keep things more compact and allow you to use a better p/s pump. seems like the brackets from any truck with a 460 should work tho. hope this helps.
Jeffs Bronco Graveyard has them (made by L&L) also, March Pulleys makes a set, if you cant find a set of brackets off a 460 truck or van from the same era
