Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-15-2004, 11:03 PM
68 351 bronc is starting off with a positive reputation.
problems with a full roll cage?
I would like to install a 6 point cage in my EB. Can the original parking brake still be used? Could I open the glove box? could I roll down the windows. Could the kids still climb in from the front? Would I have to drill holes in my rear fender wells? What info could any body give me about the roll cage/ soft top combo?
__________________
2001 F250 V-10 auto XLT 4X4
68 Bronco GT40 351w, NV3550 5sp, sweet!!!
  #2 (permalink)
Old 01-16-2004, 01:39 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
It depends on the style of cage you plan to use and how it is positioned. The most common is the smittybilt style. If you plan where you want the forward supports to go, you should be able to avoid most problems. You should be able to roll the windows down with no interference. You may have some trouble with the wing windows though (they will open, but you need to open the door to do it. I wouldn't move the forward bars in to avoid them, because it will compromise strength.
I have seen several solutions for the E brake. The simplest way is to remove the bolt that mounts it to the dash and bend it out from behind the bar reattach it to the dash. I've had mine this way for several years and it works just fine with no binding.
There are also several ways to do the glove box, depending on how creative you want to be. The cheap way would be to cut off just enough of the door so that it will clear the bar and leave the small opening that was cut. Or you could take the piece that you cut out and mold it into the dash. Or hinge it so that it will fold into itself. I've also seen some sliding hinges that allow the glove box door to slide towards the middle of the dash once it is opened. On the extreme end, I've seen many that have relocated the whole glovebox toward the center of the dash, where the radio speaker is. I've personally gone the WAYYY cheap route by removing the door altogether and losing it somewhere in my garage
For just a standard 6 point cage, you shouldn't have any problem with access to the back seat.
Most of the weld together or complete kit form cages mount to the floor (usually 3- 5 bolts per attachment), and also tie into the bed rails for support.
If you're planning on a weld together cage, you definetely want the final welding to be done by someone who knows what they're doing. Some gusseting at intersections and some way to tie in the floor supports to the frame would be a big plus.
Jason
__________________
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
Missing your Prius, check under my tires...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
