370 to 460 swap
370 to 460 swap
Since the 370 and 460 are in the same engine family, will a 460 be a bolt-in swap for a yucky 370 in an '82 F-600? I've searched shops that have remanufactured engines for sale and noticed that the 460 is actually cheaper than the 370. But there must be some kind of catch for a 370 to cost more than a 460. Is there any difference between these engines besides displacement that would prevent a swap such as this? Since the engine will be pulled anyway, might as well throw in the largest displacement of it's type huh? And I don't even know why Ford used such a small engine in a big truck when they already had the 460. But if for some reason the 460 won't work, can I make a 460 out of my 370 by adding the 460 crank, rods, and pistons and over-bore the block? I just gotta have a 460, this 370 stinks! Thanks for any help.
While the 370 may not be a powerhouse, it is a tough motor. It wasn't built to win races it was built to lug around a 20,000+ truck. Your truck will probably run better with a 460, but I can tell you the 370 is more durable. Ever thought about an industrial 429? Just as durable of a motor with some more cubic inches to satisfy your craving. And it is a direct bolt in swap.
How is the 370 more durable than the 460 since they are basically the same engine? Does it have a four-bolt block, gear-driven cam, or something that would make it a "truck" engine? But if there are reliablity issues, I guess I'll just go with that industrial 429 that you mentioned. Is there a way to put the 460 crank and stuff in that 429? Thought I'd ask.
Industrial engines have steel cranks with a bigger snout. I believe they also have larger valves, but I am not certain of that.
I am not sure about the journal size of the cranks, so I dont know if they can be swapped or not.
I do know that the only difference in a 370 and a 429 is the bore. The cranks can be swapped.
jmss123
31
06-05-2023 10:14 PM
Andrew Ford
10-18-2016 06:50 AM
ddsprint
06-27-2008 07:44 AM
gabraham
06-16-2003 06:41 PM
