torque spec for 302 exhaust manifold
Following up on a 16+ year old thread...
Ford's manifold bolts have captive lock washers, designed to keep the bolts tight. But it doesn't hurt to check them after a couple of heat/cool cycles.
If you use the hardware included with most aftermarket headers, you should definitely check them periodically.
I've never tried those "stage 9" bolts with the C-clips on the heads, but their design prevents the bolts from turning after you install them. But quite often, the header flanges don't prvide enought room to use them.
MiddleNameMUD
06-20-2011 06:07 PM
Smokejet
05-11-2004 05:27 PM
Smokejet
05-11-2004 11:34 AM
