problem with new F-150 2004 model
Shudder from Backend
I have the shudder as well. It only occurs when I accelrate and the Truck is cold or sat for awhile (2-3 hours). I am taking it into the dealer tomorrow for a look. Another guy at work has a Lariet SCrew (mines and FX4 SCrew) and he isaid t was the fluid as well, but also that it was not a cure all. His did, and is still doing, the same thing but not as bad once his fluid was changed. We both have limited slip.
I will keep you all abreast, but I have to admit, I'm not going to be too happy unless it is completely fixed.
I had this problem with my 04 F-150 STX about one month ago. It only had 800 miles, and just died, and would not start back up. At first the dealer thought I had run out of gas, but later they discovered that it was the "throttle position sensor". They put in a new sensor, and according to the report, a new pedal as well. Since then, everything's been great.
