Powering Steering Fluid VS. ATF - Ford Truck Enthusiasts Forums
Old 01-15-2004, 11:29 AM
92 Red F150 92 Red F150 is offline
92 Red F150 is starting off with a positive reputation.
Last summer, I installed a CarQuest rebuilt power steering pump on my '92 F150. It is the C-11 pump. My Ford manual says to use a Premium Power Steering Fluid E6AZ-19582-AA (ESW-M2C33-F) or equilvalent on the C-11 pump. I flushed and refilled with CarQuest Type FA automatic transmission fluid per my local Carquest dealer's recommendation. On the back of the CarQuest Type FA ATF bottle, it states that this fluid meets Ford specification (M2C33-F) and therefore I believe this is why the CarQuest dealer recommended this fluid. The pump works fine and is not noisy at all. Am I in error in using this ATF fluid in my power steerring pump? Is there a difference between a power steering fluid that meets spec (M2C33-F) and an ATF fluid that also meets (M2C33-F)? Thanks, Charles
Old 01-16-2004, 12:31 PM
85351ho 85351ho is offline
85351ho is starting off with a positive reputation.
lol ive been running dex III for 5 years or so...ever since the ford dealer told me it was ok, and ive never ever had a ps pump take a dump on me
Old 01-17-2004, 07:23 PM
hdgapeach hdgapeach is offline
hdgapeach is starting off with a positive reputation.
ATF will be fine in your power steering pump. Auto transmissions and power steering pumps are both hydraulic pumps. The reason for specifics in ATF for trannys is because of all the other goodies inside the case besides the pump like bands, clutches, diaphrams, seals and gaskets. Some of these will deteriate if the wrong type of ATF is used. The power steering pump has a couple of seals and hydraulic hoses and a gearbox. All components of these systems are pretty much bullet proof with minor maintenance. That is why most agricultural eguipment rely on hydraulics. Any type of hydraulic oil will sufice in the steering pumps.
Old 01-18-2004, 04:47 PM
Thanks for the replys. I'll just stick with the Type FA then. Charles
Old 02-08-2005, 12:39 AM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
I'm getting ready to redo the steering system in my 79. new pump, hoses, gearbox and filter. the old system had ATF in it and it lasted 25 years (well the pump was only 13 years old).
I will probably use ATF in the new system
power steering fluid tradingden Oil & Lubrication 23 03-11-2012 06:56 PM
swap power steering pump f100_4me 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-18-2008 06:49 AM
Power steeging fluid straightsixer 1987 - 1996 F150 & Larger F-Series Trucks 7 02-01-2008 03:39 PM
Steering whine- - - Fluid questions DOUG5G Aerostar 20 01-01-2005 06:03 PM
power steering fluid brown 4x4 1987 - 1996 F150 & Larger F-Series Trucks 10 02-02-2003 01:42 AM
Tags
atf, brake, difference, e6az19582aa, f150, fa, fluid, ford, hydraulic, power, steering, trans, transmission, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
