Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-14-2004, 06:46 PM
WXboy's Avatar
WXboy is starting off with a positive reputation.
Why is this called "pre-powerstroke"?
Ford added the turbo to the IH diesel in 1992, and from that point on they got "Powerstroke Diesel" badging. So what's up with the name of this forum??
__________________
2003 Ford Ranger S/C FX4
  #2 (permalink)
Old 01-14-2004, 07:20 PM
BSmitty is starting off with a positive reputation.
They may have been labled that (don't know) but the actual Power Stroke is defined by it's injection system. And the real Power Strokes didn't hit the streets till late 94 and 95. The 7.3 turbo was not the same as a Power Stroke. So this site is dedicated to the 6.9/7.3 w/stanadyne pumps. Hope this clears it up for ya.
__________________
^Candy^
1985 Ranger 2wd Explorer edition, 2.3l TK5. XL without power steering, brakes, etc.
Daily Driver;
1992 Ranger 2wd 2.3l M5OD, Custom cab with A/C, Cruise, P.S./P.B. Currently 211,xxx and counting...
  #3 (permalink)
Old 01-14-2004, 09:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
The pre Power Stroke diesels are the 6.9 and 7.3 IDI (Indirect Injection) motors which were installed thru and including the 94 model year. Injection on this motor is mechanically controlled and the only wire that must be installed for it to run is the fuel shut off solenoid on the injection pump. It also has a mechanical cable to connect the throttle pedal to the injection pump.
The Power Stroke 7.3 DI is a direct injection motor that was first introduced in 94 1/2 through the current model year. It is computer controlled and has to many wires on it to make it run. The throttle pedal is even hooked to the computer instead of the injection pump.
I do not think the Power Stroke name was implyed or used untill the DI motor in 94.
The 7.3 IDI turbo was called the 7.3 Turbo Diesel for 93 and 94.
To my knowledge the 92 did not have the turbo option.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 01-14-2004, 11:01 PM
Spectramac's Avatar
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
If it was up to me I would have labeled this section of the forum "6.9 / 7.3s", then the next one "PowerStrokes".
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #5 (permalink)
Old 01-14-2004, 11:21 PM
Well you know....Pre Power Stroke.....Pre historic.....Pre Civil war
They are trying to tell us we are old news, antiques, over the hill or some such crap as that.
I kinda think we are like fine wine, the older the better.
Besides, my total operating expenses for my truck last year were 5,857.92. That is repairs, tires, fuel, insurance and license plates on a daily driver only vehicle. Let one of those 6.0 Power Stroke guys beat that.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 01-15-2004, 12:43 PM
OwhoOSU is starting off with a positive reputation.
I am new to this site, I have just bought a 1994 F350 7.3T that has a "powerstroke diesil" badge and was shocked to find that the VIN said it was an IDI. After reading the 1st post it sounds like the badge was applied stock from the factory. Very misleading (shame on ford). Consequently I have found the door tag indicating my truck came with a 3.21 rear end does not match the tag in the diff it supposedly says it has a 4.10 rear end. That explains why I am only getting 12.5 mpg empty 1/2 highway 1/2 town driving
  #7 (permalink)
Old 01-15-2004, 02:46 PM
fonefiddy is gaining momentum as a positive member of FTE.
Maybe someone changed out the PS for an IDI? Some people were not very impressed with the computer controlled PS when it first came out. ( imagine that, Ford fans afraid of progress?)
Might just be a transition truck? Maybe on Fri night they shut the line down for the engine change over. Maybe yours was stuck on the line over the weekend, and the guy stickin the badges on the trucks Mon morn. had no idea there was an IDI under the hood?
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
  #8 (permalink)
Old 01-15-2004, 09:12 PM
MRZ MRZ is offline
MRZ is starting off with a positive reputation.
I have to weigh in on this- make sure you check your vin# before you go any further- do the rivets holding the tag on the dash look original? A lot fo cab swapping goes on in the exciting world of auto body- a fine art you may say
And then you have wonderful used car lot representatives of the not so honest kind- some of them make instant "z71" chevy pickups - or maybe a stroker - with just a sticker...
That may or may not be the case here but it would be interesting what the history is on your VIN nevertheless- especially if everything is matching
  #9 (permalink)
Old 01-15-2004, 11:59 PM
checking the vin is what made me question the "badge". the vin does state the IDI. I spoke with a mechanic at a local repair facility and he verified that ford did put the powerstroke badge on the turbo 7.3L in 94' but no badge was placed on the plain 7.3L
  #10 (permalink)
Old 01-16-2004, 01:47 AM
dego red is starting off with a positive reputation.
I looked at a truck that just had the turbo diesel signs on it , and the sales guy said it was a powerstroke???? Go figure. red
  #11 (permalink)
Old 01-17-2004, 05:35 PM
ajf250 is starting off with a positive reputation.
I have seen the same kind of thing on a truck we worked on one time at work. It was a 94 with a Powerstroke, but all it had was the turbo diesel signs on it.
  #12 (permalink)
Old 01-19-2004, 09:51 AM
Frost13's Avatar
Frost13 is starting off with a positive reputation.
The PowerStroke was designed by Cat based on the 7.3 IDI.
  #13 (permalink)
Old 01-19-2004, 06:07 PM
mhalter's Avatar
mhalter is starting off with a positive reputation.
What? The powerstroke was an International engine the last time I checked, not a Cat....
__________________
1989 F250 Lariat, N/A 7.3 idi, 4x4, C6
  #14 (permalink)
Old 01-19-2004, 06:50 PM
MRZ MRZ is offline
Quote:
A typo perhaps- we all do it from time to time
__________________
1965 fairlane
1970 cl450
1972 cb350
1974 cb550
1974 cb750
1979 f150
1983 k-20
1984 c-10 (old ladies)
1990 f350
1997 cbr1100xx
  #15 (permalink)
Old 01-19-2004, 08:41 PM
How long do you think it would take for me to have Power Stroke badges on my 86?
I think I can drive to the Ford dealer in 10 minutes from my house.
As far as that goes I think I will get V10 and Power Stroke badges and put on it, that will really get someones goat going.
Man look at that back in 86 they had a V10 Power Stroke motor, better not get in front of that guy, he'll run over us.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
