Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air tool oiler won't fill
Old 01-14-2004, 12:16 PM
joadmobile's Avatar
joadmobile
joadmobile is offline
I recently purchased an inline air tool oiler for my air tools, but I am having the strangest problem filling it. I bought air tool oil at Sears (it is pink/purplish) and when I try to pour a very small amount into the hole, it won't go in! It just puddles on top of the hole, kind of like water does with surface tension. I have tried sticking a toothpick into the hole and pouring next to it, to break any surface tension and to allow air to escape as I pour in - that didn't help. I even tried poking it down with a small screwdriver - all I got was an oily screwdriver and an empty oil resevoir. Have you guys seen this? Is it the oil I bought? I am a little new to air tools (Santa was good to me ).
Old 01-14-2004, 12:30 PM
Huntsman's Avatar
Huntsman
Huntsman is offline
I have used a hand pump oil can to fill mine, when I had one. I don't like them and prefer to oil my tools directly. I don't want the oil in the airlines due to occasional painting.
Old 01-14-2004, 04:34 PM
tigerman's Avatar
tigerman
tigerman is offline
I use a 18 gauge needle with a 3cc syringe to fill mine. It is mounted right next to the tool with quick connectors so as to move it to different impact tools. But I don't do any spray painting and I'm strictly amateur.
Old 01-15-2004, 12:01 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
If it has a very small hole you will have to fill it with a syringe of the type that is used to give kids medicine which you can buy at any drugstore.
You can check out my air tool oiler in my gallery. The hole in it is half an inch across so it is no problem to fill.
Do not use a central lubricator if you ever want to use your air lines for painting. A central lubricator does not deliver a good oil mist to the air tools either. Most of the oil ends up condensing on the sides of the airline and makes a mess.
Old 01-15-2004, 08:26 AM
joadmobile's Avatar
joadmobile
Thanks for the pics, torque1st. I planned on connecting it right next to my tools as I've read you should do. I'll get a syringe the next time I'm at the drug store and go with that.
Encho
1978 - 1996 Big Bronco
42
06-05-2021 04:42 PM
1bigjoe
04-25-2016 09:06 PM
Dannym
08-16-2015 02:13 PM
squirrel64
02-26-2014 07:07 PM
viking89
05-14-2010 09:13 AM
Quick Reply: Air tool oiler won't fill
