Pcv Valve on 88 f150 - Ford Truck Enthusiasts Forums
Old 01-14-2004, 10:10 AM
irishman200232 irishman200232 is offline
irishman200232 is starting off with a positive reputation.
Where is the pcv valve on 1988 f150 302 ?
Old 01-14-2004, 10:40 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Near the back of the passenger side valve cover.
Old 01-14-2004, 11:53 AM
thanks, i will give it a try
Old 01-18-2004, 09:08 AM
got it thanks!
Old 01-18-2004, 03:16 PM
stevieray stevieray is offline
stevieray is starting off with a positive reputation.
If you'r up to it, check pevious posts on the PCV hose. I started one a couple of years ago after I found that the hose goes right into the plenum directly in line with the #8 cylinder therefore dumping a lot of excess polutants and watervapour into the #8 cylinder. This can cause at the least a rough running engine and at worst a failure of the #8 piston. I recomended moving the hose to the vacuum tee in the center of the manifold (for manual trannys) or teeing into the brake booster line for trucks with an auto trans as there isn't a spare spigot on the vacuum tee if you have an auto trans. This was the first mod I did to my truck and it made a new truck out of it. I got the truck for a super deal because the dealer could't get it to run right. The next best mod is to block off the EGR. Both are dead cheap and cure a lot of driveability problems.
Old 01-18-2004, 04:23 PM
how do i block off the egr? do they make a plate?
Old 01-18-2004, 04:44 PM
EPNCSU2006's Avatar
Blocking off the EGR valve will fool the computer and possibly cause the truck to ping and run lean. The computer compensates for the inert gases from the egr by running less fuel, so without the egr gases, it will run lean. But the PCV relocation is a good idea and a good safety measure.
Old 01-18-2004, 10:19 PM
when i reroute the pcv hose, do i plug the plenum spout? or leave it be?
Old 02-08-2004, 07:26 AM
2BIGTRK 2BIGTRK is offline
2BIGTRK is starting off with a positive reputation.
I WOULDNT BLOCK THE EGR MAN,YOU WONT PASS SMOG FOR ANYTHING,BELIEVE ME I DONT WANT MY EGR EITHER BUT HAVING IT ON WILL RELIEVE ONE LESS HEADACHE YOU NEED
PCV valve harley3348 1987 - 1996 F150 & Larger F-Series Trucks 15 12-13-2015 07:37 PM
Pcv Valve Location justin_galens 1987 - 1996 F150 & Larger F-Series Trucks 3 11-25-2005 11:07 PM
'88 F-150 PCV Valve location gowers 1987 - 1996 F150 & Larger F-Series Trucks 2 03-28-2004 09:55 PM
pcv location 1990 4.9L f-150 paisano341 Ford Inline Six, 200, 250, 4.9L / 300 3 11-19-2003 09:00 PM
pcv valve location? coops28 1987 - 1996 F150 & Larger F-Series Trucks 4 01-30-2002 08:53 AM
Tags
1988, 351, 87, 88, booster, egr, f150, ford, located, location, pcv, problems, replacement, v8, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
