03 Explorer rear wheel bearing
just replaced the right rear bearing on mine.
The bearing comes with the hub as one part. The bearing needs to be pressed into the hub with a hydraulic press.
Getting the old hub out is a snap. Just remove the large nut at the end of the drive shaft and pull on the hub as you tab on the end of the drive shaft with a hammer. Should pop righjt out.
I have the part numbers handy if you need them.
Bearing has a little slack in it. Gonna change it soon as he gets
back to Memphis where I'm at now. Supposed to be here Mon.
if it last... otherwise a dealership will get to have all the fun...
Trans. has replaced around 70,000 or so. Had some abs problems
but didn't get to check that problem before trans went out so
dealership got to fix it when they had it.
briefly
07-07-2002 01:44 PM
