need radiator
on
1 Post
need radiator
search not working, server too busy... so...
I'm looking at Autozones 2 avaible radiators -with maximum cooling...
GDI 3 core($249), and GDI optional heat buster 4 core($229)...
Am I missing something? The 4 core is less money? Is the 4 core not as goo of a unit for some reason?
Then there are 2 listed without maximum cooling...
GDI 3 core($149), and GDI optional heat buster 4 core($229)...
Does anything look fishy to you folks?
Anyone want to recommend a good radiator for 115* Phoenix summer conditions?
on
1 Post
I checked out the NAPA rad's, looks like they come with a tranny cooler as well... or am I mis-understanding something?
Also, called RonDavis Racing Radiators, I can get a 19"x26"x2" 2 core all aluminium construction radiator with angle flanges welded to it for less than $300. I would have to drill my own mounting holes... not sure how I'd mount my fan shroud...
I have one of thier radiators in my Mustang, and it runs like it's on the polar ice cap.
I wonder if it's worth the extra $50 over the NAPA, or, $75 over the AutoZone?
I assume the Griffin's are up around $500?
For your type of heat, I would recommend the 4 core radiator. Those aluminum radiators are meant for weight savings on race cars like drag cars. You do one run down the 1/4 mile then line up again. Plenty of time to cool down between runs. But if you're driving around town, you risk overheating with a 2 core aluminum.
I can't remember the source, but we got an aluminum radiator for our 85 MonteCarlo dirt track car for around $160 and that included freight to Alaska. Even in the 100 lap races it never got above 190 and by the way was track champion. Running in 85-90 degree weather. Also there are plenty of places to get a way better deal than NAPA. Get your yelow pages out for the nearest city and call them all. I used to get most of mine right from radiator shops and from Performane Radiator Inc. I don't know if they were franchised or not.
on
1 Post
the autozone 4 core is $230.
for $30~50 more I could have an alum. one, but, if it's not need'd, then, I'd like to hang on to that extra money.
I have an alum. one in the Mustang because with our club discount, it was actually cheaper than a 4 core unit from autozone
The thing I like about the autozone or napa ones is I know they will bolt directly in, and the fan shroud will bolt directly to it.
What I like about the RonDavis one is, I know I will never have a cooling issue with it...
For what it's worth, a 2 core alum. from Ron Davis cools more efficiently than 4 cores from autozone... well, at least on street driven mustangs...
While we are on this...
what does everyone run for a thermostat?
I have a 160(put in by shop) but always figured a 180 would work better... any experience?
There is some controversy about T-stats. For the most power a cooler one is probably better. But too cool isn't good either. I have found that I like the hotter ones better for winter. I picked up about 1 1/2 mpg in city driving just going from a 180 to a 205 on my 300-6 in winter. I just left it in year around. It will still open before over heating anyway.
