MAJOR ANNOUNCEMENT Predator For 6.0L
on
<b><font color=red>NEW!</font></b><h3>Diablo Predator For 2003 - 2004 6.0L Power Stroke Diesel Ford Trucks, SUVs And Vans!</h3><p align=justify><b>The Diablo Predator was engineered to raise hell!</b><p align=justify><font face="helvetica, arial, helvetica" size=2>The Predator is the world's <b>first</b> flash tuner product for the 6.0L Power Stroke! The Predator is a tunable performance module, which utilizes flash technology to reprogram the original ECU chip for optimum performance and drivability.<p>The 6.0L Predator features state of the art tuning with lower exhaust gas temperatures than external power add-on boxes.<p><b><u>Features</u></b><li>Easy to use. Novice users can select preset performance settings.</li><li>3 Performance settings!<ol><li>45 HP tow file for heavy towing</li><li>65 HP all-around use, light towing, fuel economy performance tune</li><li>100 HP, no towing unless you have an EGT gauge install</li></ol><li>speed limiter adjustments</li><li>State of the art OBD-II diagnostics live sensor reading (not just a simplistic code reader)</li><li>up to 30 minutes data logging at 90 samples per second that can be viewed on the Predator screen or uploaded to your desktop pc</li><li>Fast programming time</li><li>300% larger viewable screen than other tuners (compared to other company products for the 7.3L Powerstroke)</li><li>Backlit screen allows you to use the tool in full sunlight or total darkness</li><li>Full text OBD-II Diagnostics + diesel specific diagnostics</li><li>Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.). Over 100 parameters can be monitored in real time.</li><li>Read and clears DTCs (Diagnostic Trouble Codes) with full text DTC explanation.</li><li>Can reprogram performance tune or restore stock tune <b>even if dealer reflashes the ECU</b></li><li>Port which will allow future download of updates</li><li><b>Lifetime Warranty!</b></li><p><b><font color=red>FREE OVERNIGHT SHIPPING!</font></b>
We expect to begin shipping on Wednesday, January 13th.
Hurry! Intial Quantities Are Limited and only a few dealers in the world will have it!
Go Here to order --- > > http://www.motorhaven.com/customer/p...cat=217&page=1
And from what I gather the latest flash was 12-12-03 or there abouts, which I DO have.
Flash Matrix
THANKS !
Flash Matrix
THANKS !
Questions, questions, questions
So are you saying this is perfectly safe on a 2004 6.0L PSD with the latest flash or at least I can reinstall the factory flash if something does go wrong?
I've owned my truck for a month and have approximately 1800 miles on the engine -- should I wait a little longer before adjusting the horsepower?
I'm new to this diesel game but I'm itching for a new toy to increase performance. What else do you recommend having in place when using the Predator?
Re: Gauges & Exaust?
Originally posted by BagStroke
With this new Predator do you need gauges and exaust or will it work (stock) safely??
DARN YOU KEN !!!!!
You got the Predator to me too soon !!!
SHUCKS !!!!!!!!!!!!!!!!
my predator just came in and I don't have gauges yet...
Anyone giving odds if it stays in the box or not ?!?!
(I'll take that bet, too !!!)
bye - gotta go play !
on edit - Ken can you pm me on autometer gauges, I think thats the consensus on what will match my interior...
EGT at elast,
boost as a possbility,
and mounting if I don't want to remove my grab handle...
Thanks again for superior service !
EGT at elast,
