You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Diablo Predator For 2003 - 2004 6.0L Power Stroke Diesel Ford Trucks, SUVs And Vans!
The Diablo Predator was engineered to raise hell!
The Predator is the world's first flash tuner product for the 6.0L Power Stroke! The Predator is a tunable performance module, which utilizes flash technology to reprogram the original ECU chip for optimum performance and drivability.
The 6.0L Predator features state of the art tuning with lower exhaust gas temperatures than external power add-on boxes.
Features
Easy to use. Novice users can select preset performance settings.
3 Performance settings!
45 HP tow file for heavy towing
65 HP all-around use, light towing, fuel economy performance tune
100 HP, no towing unless you have an EGT gauge install
speed limiter adjustments
State of the art OBD-II diagnostics live sensor reading (not just a simplistic code reader)
up to 30 minutes data logging at 90 samples per second that can be viewed on the Predator screen or uploaded to your desktop pc
Fast programming time
300% larger viewable screen than other tuners (compared to other company products for the 7.3L Powerstroke)
Backlit screen allows you to use the tool in full sunlight or total darkness
Full text OBD-II Diagnostics + diesel specific diagnostics
Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.). Over 100 parameters can be monitored in real time.
Read and clears DTCs (Diagnostic Trouble Codes) with full text DTC explanation.
Can reprogram performance tune or restore stock tune even if dealer reflashes the ECU
Port which will allow future download of updates
Lifetime Warranty!
FREE OVERNIGHT SHIPPING!
We expect to begin shipping on Wednesday, January 13th.
Hurry! Intial Quantities Are Limited and only a few dealers in the world will have it!
So are you saying this is perfectly safe on a 2004 6.0L PSD with the latest flash or at least I can reinstall the factory flash if something does go wrong?
I've owned my truck for a month and have approximately 1800 miles on the engine -- should I wait a little longer before adjusting the horsepower?
I'm new to this diesel game but I'm itching for a new toy to increase performance. What else do you recommend having in place when using the Predator?
Hire a full time staff, put in thousands of hours over several years building and promoting a site, fork out a ton of money each month maintaining it and you can advertise "your crap" on it.
Originally posted by BagStroke With this new Predator do you need gauges and exaust or will it work (stock) safely??
Exhaust will help keep you EGT a little lower, but you'll never know unless you install the gauges. I'd recommend gauges as the first step in everyone's mod process. However, technically speaking, gauges have no effect on performance or your mods- they just let you know what effect the mods are having on the system. I'm installing gauges now, will monitor and record performance and parameters as stock, then will have a baseline as I do modifications. When done, I’ll have performance and parameter changes for each mod. If something goes wrong, I’ll know where to look to get back to where I need to be. Can you tell I do flight testing?
SHUCKS !!!!!!!!!!!!!!!!
my predator just came in and I don't have gauges yet...
Anyone giving odds if it stays in the box or not ?!?!
(I'll take that bet, too !!!)
bye - gotta go play !
on edit - Ken can you pm me on autometer gauges, I think thats the consensus on what will match my interior...
EGT at elast,
boost as a possbility,
and mounting if I don't want to remove my grab handle...
Thanks again for superior service !
__________________
13 F-350 Platinum 6.7 CC SB Tuxedo Black Metallic 11.5k gvwr,
13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost Tuxedo Black Metallic.
12 MVP Destiny 355RE 5th wheel
gone-12 F-250 6.7 CC SB Sterling Grey Metallic Lariat w/ Ultimate Pkg. MBRP filter back Exhaust, Airlift air bags.gone-05 Ex 4x4 6L,even goner-2002 4x2 7.3L Ex Limited
GoEIB1,
That a good question. Also, it says I can get my stock tune back. Is that the flash I started with. I would love to get the MPG back I can deal with the hard start up.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
