Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2004, 08:21 AM
GLASMECH is starting off with a positive reputation.
Resistance Values
Sorry Guys and Gals, I just posted this in the wrong spot! Must be the weather? Lots of snow! Anyway I am working on a 1992 E-250 with a 5.8lt engine and with the key on I have a resistance value of just over 1 OHM in the ground wiring. With the key off I have no resistance? What is my best route to find what is giving me the resistance? Pull Fuses? Disconnect components? I am sure there are lots of options? I am hoping that someone may have come across this before.
Your help is appreciated,
Thanks,
David
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2004, 08:25 AM
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
From what 2 points are you measuring ground resistance??
Ground is not switched by the key, only +12V is switched, so I don't understand how turning the key on and of is changing ground resistance. You may be seeing a very small voltage drop with the key on that is effecting the OHMS reading on your meter.
  #3 (permalink)
Old 01-13-2004, 04:37 PM
Mustang 5.0's Avatar
Mustang 5.0 is starting off with a positive reputation.
You'll have to be a bit more specific as to where you are taking the measurment at. component and contact number. voltage can read thru components, such as a light bulb. to read one ohm, you must be using a digital multimeter.
__________________
Tom Stangler
89 E-150 351W Tow rig for my Mustang
Virginia Beach, VA
  #4 (permalink)
Old 01-13-2004, 05:22 PM
I checked the resistance from the wiper motor ground to the battery ground, both key on and off. Digital multimeter was used, perhaps my choice of tool was not acceptable? Could someone please shed some more light on this subject.
Thanks,
David
  #5 (permalink)
Old 01-13-2004, 05:43 PM
Digital meter was ok.
I'm using a Haynes that covers up to 91. So there might be some difference. That said.......
If you unplug the wiper motor, and run resistance between the wiring harness plug, to ground, there should not be any difference with the key position.
if there is, that ground is missing/corroded.
According to my Haynes manual , the dash lights also use the same ground point.
Is something not working?
__________________
Tom Stangler
Virginia Beach, VA
  #6 (permalink)
Old 01-14-2004, 09:50 AM
It started with a problem wiper motor that would not park so I started the diagnostic tree and found this ground problem. I have since repaired the motor, the pins were not completely touching for the park to engage when the washers were used. However this leaves me the question of the ground resistance? Normal or not? I would expect not, either with key on or off. As I have previously said the resistance is only there when the key is on. I do not see any other problems at this time and although the original problem and reason I posted is finished I am still interested in finding out the reasoning for the resistance in the ground wiring with the key on. Maybe by figuring this out I can divert a future problem and possibly save the computer or other electronic device that will certainly get affected by something like this.
Thanks for your interest,
David
  #7 (permalink)
Old 01-14-2004, 10:03 AM
I don't think you have a problem, and the increase in resistance you are seeing is not real. The extremely small voltage drop you are seeing (millivolts) is affecting your meter, trying to measure
resistance. To verify this, try switching your meter leads, and you
will see a negative (-) resistance reading with the key on!!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
