Power window relay? - Ford Truck Enthusiasts Forums
Power window relay?
Old 01-12-2004, 02:38 AM
ottosmom ottosmom is offline
ottosmom is starting off with a positive reputation.
Question Power window relay?
All 4 of my power windows aren't working. They all stopped at the same time. My moonroof still works. I have the Chilton manual, but it sucks, and I can't figure out which relays control the power windows. I am figuring it must be a fuse or relay, but I can't make heads or tails of this stupid Chilton manual. The only other thing that the 4 windows share is the ground wire, which I can't seem to find, either.
Can someone point me in the right direction? With a diagram maybe? It is starting to warm up out here, and it's hard to go to the McDonald's drive-through in the rain without operating windows .
Edited to add: they don't work from any switch in the truck.
Old 01-12-2004, 03:28 PM
84ford460 84ford460 is offline
84ford460 is starting off with a positive reputation.
What year and model are you working on?
Larry
Old 01-12-2004, 08:25 PM
Sorry, 97 Explorer.
Old 01-12-2004, 08:38 PM
Look in the power distribution box under the hood. Pull off the cover to it. There is two rows of fuses-relays. You want to pull the 3rd fuse down on the left side of the bopassenger side). It will be a 30amp fuse. Replace it with one of the ones next to that position and then see if your power windows work. If so , just get a new 30amp fuse at the parts store and you're set.
Larry
1993 XLT Explorer 4x4
Old 01-13-2004, 02:46 PM
Nope, that didn't do it. Must be the ground wire then?
Old 01-14-2004, 11:03 AM
Sounds like you could be right. Check the boot on the drivers side door where the wiring runs thru. That would be the likely area for the wires to break or short. That's the door that is used the most.
If you don't find anything there , email me and I will give you aplace to go too. If I leave it here it wouldn't go over to well.
Larry
Old 01-14-2004, 05:43 PM
Ok! I found a broken wire in the boot. It is light blue with a black stripe. I am going to splice it and see if I get any windows back. Those damn wires are so tight in there.
Should I solder it or will it be ok wrapped with electrical tape?
I don;t have any power where I am working on it right now, so I will have to solder it later if need be.
Old 01-14-2004, 07:41 PM
You need to use a "butt" connector on the wire. Ared one otta do the trick. Crimp it on as hard as you can. If you don't have access to one , go ahead and tape it but plan on fixing it later.
Larry
Old 01-14-2004, 09:12 PM
Thanks, Larry! I found a wiring diagram, and that is the main power wire, not the ground after all. I will try to fix it tomorrow. Thanks for your help!
Old 01-14-2004, 09:30 PM
That's what everyone's here for.
Glad you got it handled!!
Have a good evening!!!
Larry
Old 01-15-2004, 08:02 PM
Cool
It's fixed!! $6 for a butt connector/crimper kit and it's working beautifully!
Now I just have to figure out what is wrong with the back door, LOL.
Old 01-16-2004, 09:34 AM
mason mason is offline
mason is starting off with a positive reputation.
What's wrong with the back door?
Mason
Old 01-16-2004, 11:24 AM
The rear driver's side door doesn't open. If I jiggle the lock and keep pulling on the handle, eventually I can get it open. I got it open yesterday and removed the door panel. It seems that the lock gets stuck, keeping the door locked. It doesn't pull all the way up or push down. Jiggling it seems to free it up briefly, but it soon gets stuck again.
Old 01-16-2004, 11:27 AM
As you may know rear interior door handles are notorious for breaking in Explorers. I've replaced 4 over the years. Sounds like you are having a different problem. Besides lubing I don't know how to help. Sorry.
Mason
Old 01-16-2004, 12:24 PM
Mason is correct.
Try using WD-40 or some other lube on the linkages and actuator arm. Don't spray too much on the actuator arm. You might end up having to replace the actuator itself if lubing doesn't work for you.
Not much help , but it might work.
Larry
Dome Light and Power Window trouble rifleman9 1997 - 2003 F150 0 04-12-2014 10:43 PM
98 Expy Fuse Panel : major secrets?? slaponte 1997-2006 Expedition & Navigator 24 04-22-2008 11:47 PM
Wipers, windows, Dome light, don't work droolscool Electrical Systems/Wiring 1 12-05-2006 10:02 PM
Manual To Power IR RANGER Electrical Systems/Wiring 0 09-14-2003 10:25 AM
no power windows/4WD light blinking bbillman Explorer, Sport Trac, Mountaineer & Aviator 1 05-01-2003 01:52 AM
Tags
1982, 1996, 2003, aviator, explorer, ford, located, location, mustang, power, powindwer, relay, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
